Old 12-08-2016, 02:35 PM   #1
humayun.chughtai.7
Drives: Toyota Echo 2001 4-door
Exclamation Engine won't shut off
Recently, i bought a toyota echo hatchback (same as vitz/yaris) 2001 UK Import. The car is in great condition otherwise. It is original 1300 cc with 2NZ engine in its bay.
Now the problem comes up daily in the morning time or whenever I start the car after an interval of 4-8 hours. When I start the engine, red over-heat light glows up in the cluster. During this light in the cluster, if I turns the key to ACC position to turn off engne, it refused to turn off while all the electronics of the car shuts off except engine and when I turn the key from ACC to LOCK position, the self-starter kick-in within the running engine producing a loud karrr-karrr sound. So I again turned the key to ACC position and Thank God, the starter turns off back, while the engine is still running.
This problem only happens when the engine is cold and red over-heat light glowing in the meter. After 2-4 minutes, that light goes off and everything is just as fine as nothing happened. Now I am very tensed about this weird issue. Kindly help me.
With Love from Pakistan <3
humayun.chughtai.7 is offline   Reply With Quote
Old 12-09-2016, 02:25 AM   #2
humayun.chughtai.7
plz help me ... anyone
Old 12-09-2016, 02:53 AM   #3
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Could be circuit open relay issue ..
Usually located near ECU on Toyota !
Could be loose ground point
KimmoKekki is offline   Reply With Quote
Old 12-09-2016, 09:31 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Remove the auto starter and see if your problem goes away.
9 times out of 10 the problem is with an aftermarket accessory that's been improperly installed.
Old 12-09-2016, 10:03 AM   #5
humayun.chughtai.7
Could you plz tell me, where it is located under the dash ?
Old 12-09-2016, 10:05 AM   #6
humayun.chughtai.7
I am unable to find any relay near ECU. Could u plz post a reference pic here ?
Old 12-09-2016, 10:07 AM   #7
Bluevitz-rs
How would I know. I didn't install it. The car doesn't come with one from factory.
Old 12-09-2016, 01:42 PM   #8
humayun.chughtai.7
No ... I think it was an aftermarket install by previous owner .
Old 12-09-2016, 03:55 PM   #9
KimmoKekki
KimmoKekki's Avatar
Yep yep ... mate bluevitz-rs is right !!
Old 12-10-2016, 06:55 PM   #10
SirDigby
Drives: 2007 yaris 3 door
what IS an auto starter? like remote start, or is it a start-stop, like on a hybrid? ether way i'd agree that it most likely is the issue....
Old 12-11-2016, 03:05 PM   #11
humayun.chughtai.7
But I am totally failed to find any type of auto-starter kit or its wiring under the dash, everything is in stock condition.
Old 12-11-2016, 03:06 PM   #12
humayun.chughtai.7
OK. Now,I will post a video soon to get u guys some idea about the issue.
FS 1nzfe engine and AT nuwizard Items for Sale by private party 7 05-20-2016 09:58 PM
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 09:34 AM
Stock Engine Swap whooppee777 DIY / Maintenance / Service 6 07-14-2015 11:39 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
