Old 01-25-2017, 03:06 PM   #1
tmontague
tmontague's Avatar
Public service announcement re: license plate bolts
Do yourselves a favor for those who live in the rust belt. Anti seize your license plate bolts and replace them with new ones if they're rusted.
I just wasted 2 hours of time to remove sheared off bolts that I ended up breaking off an ez out in one of them.
Replacements are M6 1.00 25mm length.
Old 01-25-2017, 03:15 PM   #2
Stainless FTW!
At least on the Gen2 HB, both front and back are bolted into plastic.
Old 01-25-2017, 03:22 PM   #3
dogsridewith
Drives: 2007 2-door hatchback
I broke an EZ-out or two as a kid. Don't use, and wouldn't except maybe for a bolt/screw drilled out until the thread base was just kissed somewhere and the remains could be collapsed and picked out. (Finally got a cheap set of reverse drill bits said to facilitate this.)
An easy out should work OK on a bolt overtorqued in a clean threaded hole that lost its head...because the remains is now loose. But if the bolt tightened up by packing rust as it was backed out, then an EZ-out in a too-small center hole is just going to swell the bolt tighter until the EZ breaks.
My 91 Corolla was covered with little 10mm head fine thread screws that had to be worked out by tiny increases in amount of CW and CCW rotation, while being dosed with PB Blaster.
Old 01-26-2017, 01:17 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
use plastic bolts for plates cos if brake easy to clean out
Old 01-26-2017, 02:17 PM   #5
dogsridewith
Might loose a plate w/ plastic screws. (Maybe somebody parks-by-ear) Hardware store trays should have stainless ones in this size. Steel installed greased would be removable for a long time.
Old 01-26-2017, 07:10 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Actually most dealership use plastic plate screws do to rusting problem with anything else , they are strong and don't come out plus if broken one can simply drill the hole out and good to go ...Five min tops .
Sent from my SM-G935F using Tapatalk
Old 01-26-2017, 08:02 PM   #7
^ not in my experience. I've never received a vehicle with plastic bolts.
Old 01-26-2017, 08:04 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Well Toyot does it and does make a huge difference.
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 09:28 AM
I'll ask again: How to mount license plate securely with no holes? BennyLava DIY / Maintenance / Service 23 06-03-2013 10:12 PM
LED License Plate Frame chrisj Cosmetic Modifications (Exterior/Interior) 7 09-22-2010 12:21 PM
Custom 3-way switch for license plate LED bolts? (on, off, blinker) BassHead DIY / Maintenance / Service 3 08-27-2010 09:55 PM
How can I cover front license plate hole hans_fh General Yaris / Vitz Discussion 13 01-03-2007 01:58 PM
