Old 02-02-2017, 12:49 AM   #1
7:34pm
Drives: 07 Yaris
Removal of manual transmission cable to get to reverse switch
Previously posted in a dead thread.
Rat chewed through my reverse switch wiring, rather than getting a new one I'm trying to lengthen the original wires.
I have two questions first:
1. Both wires are black, does the order the wires go back together matter? Because it's too late now to tell which wire goes to which.
2. How do you remove the transmission cable that's directly above the reverse switch? This one may be simple, but just wanted to be sure before going ahead.
Thanks.
7:34pm is offline   Reply With Quote
Old 02-02-2017, 05:23 AM   #2
KTS
KTS's Avatar
Drives: Vitz RS
I think it's just an open/close switch. Doesn't matter the polarity.
First you will have to remove the cutter pin that connects the cable to the lever, then use a pliers and a screw driver to remove the lock that attaches the cable to the bracket. Those locks are difficult to remove at times. Or you could just unbolt the entire bracket.
Have you tried doing the wiring from below the car? Last time I had to extend the reverse switch wire it was much easier to do from below the car.
Sent from my SM-G920V using Tapatalk
KTS is offline   Reply With Quote
Old 02-02-2017, 11:06 AM   #3
7:34pm
Drives: 07 Yaris
Thanks! However the wires are chewed on the top of the transmission, about an inch away from the sensor so I think on top will be easiest.
Will give it a shot when I have time.
Transmission oil? jamesxl DIY / Maintenance / Service 3 04-11-2016 10:18 PM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
