Old 02-05-2017, 10:01 PM   #1
Seasonaleclipse
Drives: 2012 Yaris coupe
2012 Yaris hatch vibration at 60ish mph
Just picked up a Yaris for my girl friend a few weeks ago. She drives it in the rural country side for in home health. Anyhow we took the car on a highway trip this weekend and I noticed a vibration from the front when the car reached 60-65 at 55 and under it's not noticeable. The car has fresh tires and otherwise runs without issue. It has right at 76k miles.
I'm leaning towards a wheel bearing but just wanted to see if anyone else had this issue. I saw that the older Yaris's had a vibration at this speed and it was just the nature of them could this be the same?
Seasonaleclipse is offline   Reply With Quote
Old 02-05-2017, 11:51 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
country road is your answer if dirt roads, check for dirt, mud build up in the rims and wash it out .
Old 02-06-2017, 09:50 AM   #3
Seasonaleclipse
Hopefully it's as easy as that. I just hope it's not a symptom of worse things to come. (Transmission )
Old 02-06-2017, 10:35 AM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Stop over thinking... Sounds like wheel balancing issue
Sent from my SM-G935F using Tapatalk
Old 02-06-2017, 12:06 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
My vote is a wheel out of balance. Just because they're new tires doesn't mean they were balanced properly.
Old 02-06-2017, 12:16 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
... I noticed a vibration from the front when the car reached 60-65 at 55 and under it's not noticeable. The car has fresh tires and otherwise runs without issue.
Sounds like wheel balance or perhaps a bad tyre.
I never heard of this!
Old 02-06-2017, 12:41 PM   #7
I think you are referring to a harmonic hum which manifests itself at around 60mph. There are no reported, that I'm aware of, issues stating the car starts to shake at that speed.
Old 02-06-2017, 01:33 PM   #8
Seasonaleclipse
Yeah this is more of a pulsation at around 60- 65. It kinda goes like a mmm pause for a half second then another mmm. You can feel it in the floor board. But at 55 you don't notice it.
I am a worry wart though I figure I'll get it looked at when we do a oil change.
Old 02-06-2017, 01:43 PM   #9
dogsridewith
Drives: 2007 2-door hatchback
bent rim tire bulge still balance shake shimmy vibrate
and the balance machine happily balances a bent rim and/or lumpy tire. Operator needs to see these things that also cause vibration.
Old 02-06-2017, 01:54 PM   #10
Seasonaleclipse
Yeah I'm hoping that's all it is. I'm just used to her old car (2000 cavalier) being broke down every other week. I'm a hypochondriac when it comes to automobiles. Lol
Old 02-06-2017, 03:55 PM   #11
David C
Drives: White '07 3dr LB
I get it too, but a little more spaced out, more like 2 seconds mmmm and 2 seconds pause, and it happens on several different highways when I'm driving about 55 and up. I figured I was hearing things in my head since there's no vibrations, just the hmmmmming noise. I think there are sounds that could be far worst and alarming than my Yaris humming the hundreds of miles on my road trips. Maybe it's purring ;)
Envoyé de mon iPhone en utilisant Tapatalk
Old 02-07-2017, 02:08 AM   #12
dogsridewith
Beating? tire tread noise
Could be "beating" phenomena--happens when two pulse generators are just slightly out of phase. Like tread blocks hitting pavement on two almost identical front tires. I noted something like that w/ new-to-me 2007 on all seasons on factory steelies. Also loud road noise...had me doing the S-swerves test to check front wheel bearings. Put on 4-set of well worn but amazingly even winters on Mazda steelies and note how loud they are. (Without noting the beat.) Solution: turn off radio and enjoy listening to the very different sounds of different surface textures, gravel and sand coatings, rumble strips, water...
Old 02-07-2017, 02:18 AM   #13
David C
I only hear my car when I don't turn on my sound system :D
I have my head unit switched and powered from my secondary battery, so it's independent from the ignition key position.
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 03:32 PM
will 2010 Yaris wheels fit 2012 Yaris? yaris8888 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-25-2012 12:36 AM
