#19 |
what is an "off valve?"
#20 |
#21 |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
#22 |
![]() Drives: 08 Yaris HB Join Date: Aug 2009
Before paying someone to investigate further I would go ahead and try a new PVC valve yourself, I am guessing they cost around 10 bucks at Napa... Maybe double at a dealer :-) . Even without much experience, You can probably replace it yourself as there is not much to it. You can watch a video here. I think this site allows youtube links. If not just search for yaris pcv replacement or something like that.
https://www.youtube.com/watch?v=VikC_7NlIy8 I would still check again for burning oil. Have someone stand behind your car when you first start it up in the morning. You may see a quick puff of smoke once in a while that only happens on startup. That would lead me to believe its possibly your valve guides wearing. Also have someone drive behind you.. If they see some smoke while driving this could point to being rings. But as mentioned before, a compression/leakdown test is good for really verifying that. But either way... I would try the PCV valve first as its the cheapest. If that didn't work and since you are planning on getting a new car in the future, If it were me, i would just keep the oil topped off until I got the new car. Doesn't sound like it is hindering the performance or the way it drives at this point. This is assuming you are not keeping the yaris once you get a new car. So might not be worth the 1.5k to 2k investment of a new engine if you plan on getting rid of it in a few months. |
#23 |
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
Don't know how fast you are using oil, but if it was using it really bad it would be smoking out the tail pipe. These cars only hold a little less than 4 qts. I would replace the pcv valve, they aren't to expensive and can be changed in 5 or 10 minutes, check your oil every day, write your mileage down when you add oil so you will know about how many mile you can drive before it needs more. When you park overnight, try to park where the pavement is clean, then in the morning when you move the car look where it was sitting to see if there is any oil on pavement. Next time you have to add a qt. of oil, put a qt. of lucas oil stabilizer in it instead of oil, could slow the oil loss down and help with blow by. You can buy a lot of oil for $2000 dollars, I would just keep it full of oil and drive it, if bites the dust before you get your next car, just have a junk yard engine put in. These cars have aluminum blocks and it may need a new block, never know what you will find when it's taken apart, $2000 overhaul could end up being $4000 once they get into it.
#24 |
Just another thought on your car. It could possibly have so much sludge on top of the cylinder head that the oil can't drain back down into the oil pan, would have to remove the valve cover to see.
#25 |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
#26 |
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
Not even 1 liter / 1000km shows clouds of blue smoke..
Check the condition of your engine to figure out if your oil consumption is from worn piston/rings/cylinder, valve seals . Compression test , leak down test , pull a spark plug and see inside or on the spark plug for heavy oily residue. Thick oil is just a temporary bandaid and might work for an engine with loose tolerances . good luck. |
| Checking oil in the Yaris | jb48 | General Yaris / Vitz Discussion | 16 | 09-15-2015 04:15 PM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-06-2012 11:37 PM |
| Did they increase the oil capacity for 09 Yaris? | 2007yariz | DIY / Maintenance / Service | 8 | 05-18-2011 09:28 PM |
