Old 03-01-2017, 08:58 AM   #1
2004 echo alternator amps?
alternator seems to be giving up the ghost on my echo....battery light came on this morning...goes off at highway speeds (rpms/load)
what is the amperage of the replacement alternator? im seeing 70 80 and 90amps...
thanks!
Old 03-02-2017, 01:57 PM   #2
B.B._07
Drives: 07 5dr
The Denso OE alternator is 70A, if you're not running some crazy stereo system I don't really see the need to go beyond that. There is a issue with the alternators in the Yaris with corrosion forming on the voltage regulator terminals inside the regulator. Toyota issued a TSB advising replacing the alternator but you can take it apart and clean off the corrosion quite easily once you remove the alternator.
https://www.youtube.com/watch?v=kAKLeeQWCW8
New and reman alternators are quite pricey so I'd suggest the repair method or a trip to a salvage yard.
Old 03-02-2017, 02:33 PM   #3
90A was actually cheaper than 70 or 80 amp
bought a rebuilt model with a lifetime warranty for $120. installed it this afternoon..
need to take the car for a drive to charge it up
2005 Echo RS Cluster in a 3DR 2004 Echo Liftback . mpcv2000 Canada 73 05-20-2021 07:14 AM
2004 Canadian Echo Hatchback Fog light Kit ( OEM Style ) mpcv2000 Cosmetic Modifications (Exterior/Interior) 26 04-06-2017 12:25 PM
FS: 2004 Toyota Echo RS Hatchback ldd Cars for Sale by private party 0 11-15-2015 09:04 PM
Toyota Echo 2004 xoretrofuturist Australia 0 07-03-2012 09:18 PM
[Q]Yaris Front Lip + Echo 2004 HB? NotMad Cosmetic Modifications (Exterior/Interior) 0 06-28-2012 03:31 AM
