![]() Drives: Toyota Echo RS 2005 Join Date: Dec 2016
STP Injector Cleaner
waste of money ?
This detergent really cleans injectors? On the recommended bottle every 10,000km or 6,000 miles Help keep clean injector * is it necessary
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
Even Toyota has a product branded and its 350ml in european market.
Its preventative maintenance . Wont do miracles and wont hurt either. I use it every time I get a chance. :) |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Dec 2014
you want a product with PEA, polyetheramine. that's what does the actual cleaning. gumout, techron, and even a motomaster fuel system cleaner in canada, all have pea in them.
#4 | |
![]() Every 6000 miles? You gotta be kidding me! ![]() Never had a problem with gunked up injectors and Im 60 years old and keep my cars at least 100k miles. ![]() But I also use brand name gas.
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Most mechanics that work on a lot of modern Toyota's and Honda's will tell you it's not needed and more a waste of money. If your car is properly maintained you won't need. When I bought the Yaris I got some STP fuel injector cleaner in one of those car care bundles from Walmart and I must say I didn't notice any actual difference. I think it's only worth it on old vehicles with lots of miles that have much simpler and less efficient fuel injection and emission systems.
I like BG products. I would only use 44k or supercharge II
Just use top tier gas and none of that cheap stuff that will cause clogged injectors and carbon build up on the valves.
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
better to clean the injectors physically.
i decided to remove and clean it when there was minor o-ring leak that turned to be a major fuel leak. Last edited by rayfloyd170; 09-19-2021 at 04:12 AM. Reason: already cleaned my injectors physically |
![]() ![]() Drives: VERSO S Join Date: Jul 2021
Clean the injectors via fuel line method and then u can see the difference.
These additives makes very little difference. suggested by Ex Toyota Engr. |
| Do stp cleaners work? | gabriel2012 | Fuel Economy Forum | 14 | 08-27-2011 08:10 AM |
