Old 03-10-2017, 06:12 PM   #19
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Where did you pick these up?
Old 03-10-2017, 06:57 PM   #20
05echors
Drives: 05 echo rs
Guys update I was just going to pick up the fouler on the way back before I left of scanned my echo and found had a pending code with the p0420 cat efficiency and all but my o2 sensor was ready, quickly went to the nearest oil changer and by my advantage there was one just at the corner where I was going out, e-tested and passed I would like to thank you guys for ALL your feedback looks like I had a big enough time window to monitor it and take it in right away with one readiness not complete.
05echors is offline   Reply With Quote
Old 03-10-2017, 06:59 PM   #21
05echors
Drives: 05 echo rs
Car-quest they have pretty good stuff like these, they were about $10 each I didn't buy them but if I didn't pass that's the route I would have went.
Old 03-10-2017, 07:01 PM   #22
tmontague
tmontague's Avatar
This means that you can still pass an e Test in Ontario with one check not ready. Good news.
So you had a pending code but no cel? I'm confused to the status of your ecu readiness when you got the test done.
Old 03-10-2017, 07:24 PM   #23
05echors
Drives: 05 echo rs
Yes that's correct you can get away with one being not ready in my case it was the Catalitic system monitor that was not ready everything else was ready I did not get a engine light during this time but I had a p0420 fault pending Not current- stored but no engine light. Got to the test place just in time before the ecu completed the Catalitic system cycle which was the last one being checked (incomplete) according to my obd2 reader which I had plugged in the whole time there.
Old 03-10-2017, 07:36 PM   #24
tmontague
tmontague's Avatar
Ok ya that's what I figured, same way I passed last year. Good to know that hasn't changed when they updated the rules
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 12:29 PM
Engine light came on but seems to run fine naossoan DIY / Maintenance / Service 7 06-10-2013 05:51 PM
check engine light, engine turns but not start willygoodness DIY / Maintenance / Service 10 07-23-2012 06:10 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 02:43 PM
