![]() Drives: Toyota Echo RS 2005 Join Date: Dec 2016
Trailer with echo 2005 HB tow capacity ?
Hello,
I call Uhaul max trailer size is 5x8 little move with toyota echo hb ? Load 800LBS MAX ? Overweight Risk broken the chassis? |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
nope, yer good
use 3rd gear, no 4th on heavier loads
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
![]() ![]() Drives: 2000 SCP10, 2001 NCP13 Join Date: Jul 2016
I've towed 1400+ lbs (and once over 1600) multiple times with no issues.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I have a 2012 Yaris, so these figures may be a bit different for your echo.
The Australian manual for the Yaris lists a maximum trailer weight of 900 kg (1984 lb). This is reduced to 550 kg (1216 lb) if the trailer does not have brakes. 800 lbs is well within the capability of the Echo or Yaris.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| 2005 Echo RS Cluster in a 3DR 2004 Echo Liftback . | mpcv2000 | Canada | 73 | 05-20-2021 07:14 AM |
| Hi im new here i bought Toyota echo RS 2005 | frank2005 | General Yaris / Vitz Discussion | 21 | 12-12-2016 09:27 PM |
| Toyota Echo 2005 RS Performance Upgrade Help | tattoo007 | Canada | 4 | 03-10-2016 09:30 AM |
| 2005 Echo RS Performance Upgrade Help Required!! | tattoo007 | Performance Modifications | 2 | 03-08-2016 06:24 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
