Old 04-20-2017, 05:53 PM   #253
Eduardo_mty
can i use this https://www.aliexpress.com/item/High...e-b2f5a6af3066
Eduardo_mty is offline   Reply With Quote
Old 08-01-2017, 08:28 PM   #254
laobo
Drives: yaris sedan 2011
Dear Friends!
Tell me known yaris sedan 2011with 1.3 /2NZFE engine, also Yaris sedan 2014 with 1.5 engine can be to installed CCS ? Thanks a lot!
laobo is offline   Reply With Quote
Old 08-08-2017, 02:30 AM   #255
laobo
Dear CTScott.
I m looking for pin ccs from ECM for vios\yaris sedan 2014-2015. Tell me pls
Old 11-09-2017, 03:00 PM   #256
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
Hi I have yaris 2013 multidrive. Is it possible to add cruise control on it?
Sent from my SM-G935F using Tapatalk
HDTechVideo is offline   Reply With Quote
Old 11-14-2017, 09:49 AM   #257
HDTechVideo
Installed cruise control and its working perfect. Along with cruise controlinstalled speed limitter but dont think that is working, may be im doing it wrong.
Old 11-15-2017, 08:31 AM   #258
bilucci
Drives: YARIS TOUCH
Hi guys,
this is my first post inhere
I just fit the cc switch to my french made Yaris 2012 NSP130L 1.33L gasoline with 1NR-FE engine and 6 manual transmission, but the cruise light won't come on when switched ON.
has the radio touch system with the bluetooth call buttons on the right of the steering wheel aswell.
any advices please ?
bilucci is offline   Reply With Quote
Old 11-16-2017, 04:06 AM   #259
bilucci
Drives: YARIS TOUCH
I just check the whole discussion above, 1.33L can support ccs, the 1.0 gasoline and 1.4 d4d does not
Old 11-19-2017, 12:59 PM   #260
HDTechVideo
Installed cruise control stalk and it is working perfect. Along with that installed ASL switch in the steering wheel. But it is not working. Checked the connection in the back side of steering wheel and found a light green cable is there and both from ASL and this one are connected eachother (verified using multimeter).
Old 12-29-2017, 08:39 AM   #261
milhouse
Drives: Yaris 2012 1.0 5 doors
Only the 1.33L Yaris has built in cruise control. The 1.0L and 1.4L D4D do not.
Hello
I have too 1.0 Spanish 2012 yaris
Can you tell me please a link to after market solution for my yaris?
THanks
milhouse is offline   Reply With Quote
Old 03-28-2018, 06:21 PM   #262
AndreS123
Drives: 2012 Yaris L, 2017 Yaris L
i just picked up a 2017 Yaris L, US model made in France, need to add cruise.
AndreS123 is offline   Reply With Quote
Old 03-28-2018, 09:25 PM   #263
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
I am also trying to add cruise control to my 2016 L. I am just about ready to order the parts. I have a manual so I need another switchbfor the clutch pedal. The parts I ordered and am going to install are:
1) On/Off Switch/Stalk - 84632-08021
2) Clutch Switch - 88280-42010 (For a manual transmission)
3) Stalk Cover - 45186-0D150-C0
I found a decent price online at parts.conicellitoyotaofconshohocken.com. I plan on adding fog lamps later on and I only want to take off my steering wheel cover and airbag once so I am also ordering the headlamp switch which is: 84140-47161. Let me know how it goes for you. I’m planning on watching youtube to get my bearings on the install before attempting.
Captain Yaris is offline   Reply With Quote
Old 04-08-2018, 01:59 PM   #264
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Hi all, I too would like to add cruise control to my 2012 1.33 six speed manual French built yaris.
What are the exact toyota part numbers that I will need, and when purchasing the stalk and cover, does it come with the small wiring loom for connecting it. And would anyone be able to tell me if I need the clutch switch for my car.
Also would anyone have a video of them installing it or a link to one?
Thanks.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 04-22-2018, 08:49 PM   #265
laobo
Dear. If you have diagram connection ccs for manual transmit yaris 2016-2017. Share p
Dear. If you have diagram connection ccs for manual transmit yaris 2016-2017. Share please
Old 04-22-2018, 08:59 PM   #266
laobo
Not need light on when ccs work.
Originally Posted by bilucci View Post
Hi guys,
Show me ccs diagram connect for Manual transmission .( pin of ECm, clutch pedal..
Old 06-03-2018, 06:48 PM   #267
Captain Yaris
I have a US 2016 Yaris L. I popped the airbag off and to my suprise, no wire to connect to the switch and no screws to secure the switch. Do any of you know what the deal is? I thought these things are prewired for cruise control. Also does amyone know the screw size to secure the switch? Thanks!
File Type: jpeg DA86DBDC-C063-44B6-AC9D-38D0A6B31C15.jpeg (179.3 KB, 318 views)
File Type: jpeg 1C8D15E2-DD38-40E1-AE70-1A8113ECB7F0.jpeg (182.2 KB, 311 views)
File Type: jpeg 8FB68596-F555-46A8-B283-53625D316DC5.jpeg (220.2 KB, 313 views)
Old 06-03-2018, 08:46 PM   #268
DarkShadowFox
gimme a minute.
yeah im not finding a diagram on my GSIC
looks like a trade secret thing. just like how the lane departure etc have no diagrams online for spare parts.
Old 06-03-2018, 10:09 PM   #269
Captain Yaris
Thanks for checking. Hopefully someone will have knowledge of my situation.
Old 06-04-2018, 11:46 AM   #270
Captain Yaris
I put in a call to my service advisor because it dawned on me that possibly it didn’t get wired from the factory by mistake. I’ll follow up and advise as to what I find out.
cruise control. 2012
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
