Old 05-15-2017, 02:17 PM   #1
roachslayer
Drives: 2013 SE
Maintenance Light - Code P1604 "Startability"
My 2013 with 37k miles Yaris is complaining with P1604 "Startability Malfunction".
EDIT: title should just read "Code P1604 Startability", this is not a "maintenance" light issue. Sorry, can't seem to edit title.
This list of possible issues for code P1604 is not only daunting, but completely absurd:
http://www.toyotanation.com/forum/37...l#post11223665
32 different possible causes for P1604, each of which will take hours to diagnose. Gee, where do I start?
Come on Toyota. Make codes more specific to one or two things!!! You might as well programed in ONE code for the entire vehicle that says "something is wrong". Yeah, great, can we narrow this down a bit? Absurd. Frustrating.
Here is what I know:
  • I ran the fuel down to zero (literally 0 mile range reported on the meter).
  • I noticed the Maint. light (P1604) appeared after I filled up and got home (it probably appeared before filling up, and is HIGHLY likely related to my running the fuel empty)
  • Reseting the code/computer doesn't resolve. The code comes right back.
  • The engine exhibits NO discernible issues, gas mileage as I continue to drive is just fine, all systems and performance seem normal
So, uh, yeah, where do I begin with 32 possibilities and no human perceivable problems?
roachslayer is offline   Reply With Quote
Old 05-15-2017, 02:45 PM   #2
First off, codes are largely universal and a P1604 is vague regardless of manufacturer. Don't diss on Toyota for not being specific enough.
From what I can glean from the net is there is a communication issue with the ECM. Probably gonna need a trip to the shop sadly.
Old 05-15-2017, 03:55 PM   #3
roachslayer
Drives: 2013 SE
Fair enough. Still room for improvement.
... the joy.
Old 05-15-2017, 04:12 PM   #4
While I'm not familiar with the tool, there may be enough underlying data which Toyota can see when they hook up Techstream to accurately pinpoint cause. Might not be the mechanic guessing game one would fear.
Old 05-15-2017, 11:25 PM   #5
SirDigby
Drives: 2007 yaris 3 door
well here's the thing about 32 items on the list, you DON'T HAVE all of these 32 items, like "glow plugs" or "EGR system" or "start/stop" or "target common rail pressure." does it start? if yes, then you don't need to worry about immoblizer, map, maf, starter, injectors, and other stuff that makes it run, cause it's running and those things throw faults of their own; i.e. MAF, TCV, ECT, Crank/cam position, etc. if it's the only code you had after fueling, i would guess it's a problem in the fuel system. maybe running it to low made one of the resistors in the fuel sending unit stop reading correctly. maybe some debris got into the strainer and the fuel pump duty cycle is running high. if it was an EVAP issue, you would get more faults for it. interesting. i'm gonna tink on this one...
Old 05-16-2017, 12:44 PM   #6
roachslayer
Drives: 2013 SE
Excellent point about weeding out 32 possibilities.
Given that the vehicle starts and runs fine, and given my obvious "ran out of gas" issue, I'm thinking dirty gas in the fuel filter or injector - that isn't causing a perceivable degradation.
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 09:03 AM
Maintenance Light at 80k otterhere DIY / Maintenance / Service 7 08-22-2015 11:53 PM
Sponsors List RogueYaris Sponsors Classifieds Area 14 01-05-2013 11:23 PM
Maintenance Required Light on New 2010 Yaris FPG DIY / Maintenance / Service 1 08-26-2010 07:18 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 07:56 PM
