Old 05-18-2017, 01:09 PM   #1
valjeanlk
Drives: Yaris
Car burning oil and compression results are good
Hi.
I am just a new member here. I have a Yaris French Built 2008 Car with engine size is 1L. When I accelerate hardly, a lot of grey/blue smoke coming out. I did compression test. The reading are #1 = 200, #2 =205, #3 =200 PSI. No smoke at cold start up in the morning or siting for a long time. Coolant level is not change.
I am thinking that possibility of the oil control rings are worn.
Do you have any suggestion on my issue?
Thanks
Valjean
valjeanlk is offline   Reply With Quote
Old 05-18-2017, 10:17 PM   #2
zoidberg444
zoidberg444's Avatar
What kind of oil usage per thousand miles are you seeing? My 1 litre is burning about 600-700ml per 1000 miles and has been for some time. Toyota's have issues with oil burning and piston rings. Toyota "claim" its not a concern unless its more than 1 litre per thousand miles!
UK to Nordkapp in a Yaris
Old 05-20-2017, 09:10 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
Since it doesn't smoke on startup, and smokes when hard on the throttle, it is probably the piston rings.
Old 05-21-2017, 09:49 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I'd also check your PCV valve to make sure it isn't clogged. That would cause ecsessive crankcase pressure and push oil past the rings.
Old 06-01-2017, 07:14 AM   #5
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
What is the milage on the engine ?
How much oil / 1000km are we talking about?
ncp13 is offline   Reply With Quote
Old 06-01-2017, 07:31 AM   #6
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
0,416 ltr/1000km's which is acceptable !
Mute AFR sensor would also cause oil burning ...
Send from OnePlus 3T
KimmoKekki is offline   Reply With Quote
Old 06-01-2017, 09:25 AM   #7
tmontague
tmontague's Avatar
other option to look at is your valve seals. These can be replaced with the head still on the engine with the proper tool.
As stated above, check your PCV valve first before anything as it is very inexpensive to do and if clogged will lead to excessive oil burning.
That said, your sx's sounds more like bad oil rings
Old 06-01-2017, 10:33 AM   #8
zoidberg444
Every service I pop the PCV out on mine and spray some carb cleaner through it. I always do the rattle test on it as well. I would expect it to rattle if it was working. It could be gummed up with crap and jam closed.
Sent from my SM-T713 using Tapatalk
Old 06-04-2017, 08:45 AM   #9
Bony_ahmed
Drives: Toyota Yaris SEdan
i had the same problem.....changed the PCV....problem solved. Check your PCV valve
Bony_ahmed is offline   Reply With Quote
Old 06-04-2017, 12:18 PM   #10
My oil consumption has been getting a little concerning of late. Was really hoping that the cheap and easily dealt with issue of a clogged PCV was the culprit. Nope, mine rattles like a baby's toy.
Old 06-05-2017, 12:41 PM   #11
Bony_ahmed
go for an engine swap.....1nzfe would be good enough for you
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
