Old 07-14-2017, 02:20 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
About to install pair of cams but.....
about to install pair of cam, they said you do not need to reprogram ecu with current setting (272, 9.5mm)..i am already running piggyback so i can update further setting but they said it replaces the stock cam....
hmmm anybody running cams...?
Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 07-14-2017, 05:00 PM   #2
Jason@SportsCar
You can certainly run cams with the stock ecu, you just wont see anywhere near the gains as you can with a tune. Double check the clearance when you install those cams, with the 9.5mm lift Jun cams we had to do a little machine work on the head so the lobes did not hit the casting.
Old 07-15-2017, 04:27 AM   #3
rabbito
rabbito's Avatar
thxz for the reply. i told the mechanic that i have piggyback ecu, feel free to program however he want the setting to be and he said this cams bolt-on for stock ecu...-_- so i guess ill install it and see what happens
Old 07-16-2017, 11:37 PM   #4
Yarisblu
Drives: Blue hatchback 2 door 2008 yar
Are 1nz and 2nz camshafts the same? I've read that the heads are the same...
Yarisblu is offline   Reply With Quote
Old 07-17-2017, 06:41 AM   #5
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
can't wait to see dyno charts
Fluxtasy is offline   Reply With Quote
Old 07-20-2017, 12:21 AM   #6
rabbito
rabbito's Avatar
same hp gain as JUN cam bolt on...about 15hp gain..
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
anyone have racing cams installed? rabbito Performance Modifications 2 07-17-2016 11:29 PM
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 01:42 AM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 06:18 PM
