Old 08-30-2017, 03:47 PM   #1
tmontague
tmontague's Avatar
Dogbone poly bushing
I remember someone posting on here in the past about finding poly engine mount for a VW that fits in the yaris Dogbone mount.
I cannot find the thread any more. If anyone has some info regarding this or the link to the thread please post it up. Essentially you press out the oem rubber and insert the poly one that is meant for a VW
Old 08-30-2017, 04:59 PM   #2
DarkShadowFox
https://www.google.com/search?safe=s...&bih=928#spd=0
Old 08-31-2017, 08:09 AM   #3
tmontague
tmontague's Avatar
It was a specific one, not sure if it was used as a larger motor mount or as a vw doggone. The thread had the part number and everything but I can't pull it up on searches.
The link you postedisted is just a general search so still leaves me with more Q's than A's unfortunately
Old 08-31-2017, 10:37 AM   #4
DarkShadowFox
http://powerflexusa.com/volkswagengo...kaAmsOEALw_wcB
? This
Old 08-31-2017, 10:54 AM   #5
tmontague
tmontague's Avatar
No, it was red poly. It was also much bigger in size as It has to replace the big rubber bushing in the yaris doggone. It does however have the metal sleeve in it
Old 08-31-2017, 10:57 AM   #6
DarkShadowFox
https://www.ecstuning.com/b-ecs-part...5.1105r~round/
edit:
why dont you just spend more money and order the VITZ TRD engine mounts from japan?
Old 08-31-2017, 11:36 AM   #7
tmontague
tmontague's Avatar
That link looks closer to it but still looks too narrow.
Do you have the link for the trd mount, I can never find it anywhere online and I want a stiffer mount whereas the trd is a hardened rubber iirc
Old 08-31-2017, 11:41 AM   #8
DarkShadowFox
this is mk3 I dunno if mk2 fits
http://trdparts.jp/vitz/parts.html
http://www.trdparts.jp/parts_index.html
Old 08-31-2017, 05:33 PM   #9
tmontague
tmontague's Avatar
Here
is the a link I saw before but it isn't the one I'm thinking about iirc
Old 08-31-2017, 06:54 PM   #10
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
You weren't confusing the engine mounts with these bump stops were you? I see that you posted in the thread:
http://www.yarisworld.com/forums/showthread.php?t=58523
Beatrush/Laile makes a nice dogbone mount.
https://www.rhdjapan.com/laile-engin...ing-ncp91.html
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
Old 08-31-2017, 07:02 PM   #11
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Yessssss... that Laile thing... I'll be ordering that asap.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 08-31-2017, 07:18 PM   #12
tmontague
tmontague's Avatar
Thanks a ton. I must have gotten then threads mixed up but realistically I'll just order the beatrish mount, seems less work in the end
Old 08-31-2017, 08:43 PM   #13
Dodge Aries K
Ordered that mount. Heck yes. That should fix the most annoying thing about my 2016... I hate how the engine rocks back and forth when you try to shift faster than you would a school bus.
Old 08-31-2017, 10:02 PM   #14
DarkShadowFox
im just looking to only use TRD stuff or toyota oem things cause im going for a purist thi g
Sent from my LG-H918 using Tapatalk
Old 08-31-2017, 10:03 PM   #15
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
No worries guys, glad I could help, I'm planning to order one myself. They're going to be baffled with all the submitted orders for the Yaris lol.
Old 09-01-2017, 10:40 AM   #16
DarkShadowFox
i wish parts werent so expensive the markup is insane.
Old 09-01-2017, 11:13 AM   #17
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
The choice to being different is an expensive one.
Old 09-01-2017, 11:17 AM   #18
DarkShadowFox
yeah but its worth it because then I know ive gotten the most I can out of my invesment, knowing that ill probably have the only legit as forigen spec as possible Yaris will just make me happy.
Im trying to make people go WOW, thats something what is it.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
Whiteline Control Arm Bushing install and Review tmontague Performance Modifications 3 06-08-2019 03:42 AM
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 02:05 AM
bushing came off metal sleeve on rearstrut? tein coilover TRD.RiC Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-18-2012 11:14 PM
alternator bushing JAMMED ! Siffleu DIY / Maintenance / Service 12 10-22-2010 11:12 AM
