Old 09-01-2017, 09:07 PM   #19
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by tmontague View Post
Here
is the a link I saw before but it isn't the one I'm thinking about iirc
it says there is cure time involved. i think they are using the Energy Suspension fill-a-mount kit, maybe?
i was going to just make my own too...
Old 09-01-2017, 09:12 PM   #20
SirDigby
Here
Old 09-09-2017, 04:40 PM   #21
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
This is also something I want, I hate that whu-whu-whu feeling when I shift hard!
MedMantle is offline   Reply With Quote
Old 09-11-2017, 12:57 AM   #22
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Well, while expensive, that beatrush mount thing was worth every damn penny. It definitely increases NVH which I don't care about but it makes it much much nicer to shift. Now, it still will "shake" or whatever if you don't give the engine some time to spin down between shifts but it's nowhere near as bad as it was. I think with a lightweight crank pulley (can't afford nor want to pull the trans off to replace the flywheel on a 1800 mile car) then it will be pretty much perfect.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 09-11-2017, 12:26 PM   #23
tmontague
tmontague's Avatar
The lightweight flywheel makes a big difference with both having to wait for the engine to slow down between shifts. I can only speak for that in the 2zr but I'd imagine it similar in the 1nz.
I'll be purchasing the beatrish mount soon as well, I'd rather have a proper mount in there. My poly filled ones have cracked due to the torque on them and not waiting long enough for them to cure
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
Whiteline Control Arm Bushing install and Review tmontague Performance Modifications 3 06-08-2019 02:42 AM
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
bushing came off metal sleeve on rearstrut? tein coilover TRD.RiC Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-18-2012 10:14 PM
alternator bushing JAMMED ! Siffleu DIY / Maintenance / Service 12 10-22-2010 10:12 AM
