![]() Drives: 2007 Yaris Join Date: Feb 2009
Looking for an alternator from a 2009+ or newer. I understand the 06-08 have a defective voltage regulator.
Is your current alternator showing signs of voltage regulator failing? Flickering or solid battery light, no DRLs?
Yes flickering and solid battery light occasionally more so after a rainfall. Read a few threads that it may be related to the regulator. I have tested the alternator with a multimeter it appears to be charging OK. Local salvage yard only has a 07 called a few places that rebuild but they can't confirm the part number until I actually show up. I believe the faulty part number ends in 21 150 and the newer part is 21151
In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
Not sure which wreckers you tried. But try standard's they also have a yard in NY state and they can bring it over if one is there. If not try Dom's, Kenny u pull or cookstown, but you'll need tools to remove it your self.
Thanks I did source a 2014 from Standard and installed it. Seems to be working well so far.
| DIY - OEM Power Window Conversion | CTScott | DIY / Maintenance / Service | 29 | 10-27-2024 11:02 PM |
| FS: OEM 15" Steelies + OEM Tires + Hubcaps | Cosworth | Items for Sale by private party | 3 | 11-20-2012 05:57 PM |
| Ultimate yaris part out, aftermarket and OEM | yaris rs | Items for Sale by private party | 25 | 06-20-2011 12:43 PM |
| OEM Parts | hatchbackkid82 | Items for Sale by private party | 30 | 12-17-2009 10:08 AM |
| FS: OEM STUFF | darkmoon87 | Items for Sale by private party | 2 | 05-29-2009 05:21 AM |
