![]() ![]() Drives: NCP91 Join Date: Jul 2012
Giving away: Toyota FIPG, Pematex black/grey, genuine Toyota axle nuts
Giving away genuine Toyota liquid gasket, also called FIPG (Form In Place Gasket, P/N: 00295-00103) and Permatex equivalents in black and grey variations. The Toyota stuff is the absolute best in the industry, by far. General Motors dealerships buy it from Toyota to supercede the crap they buy from Germany. I get one for every couple engines I rebuild and I don't need that much.
I also get a new genuine Toyota axle nut for each engine as well, but don't need them. Axle nuts are 30 mm 12-point double hex external drive, M22 x 1.5 thread pitch, fits virtually all Toyota and most Asian cars. |
Can pick some up from you this Saturday. That FIPG will be perfect for my new trans, as will the axle nuts
Radical Dreamer
Drives: off of T9 Join Date: Jun 2017
^ There's a different formula used for transmissions, it's orange; 00295-01281
If you lack driver skill, add horsepower. |
Good to know, what would the fipg typically be used for?
Yup, the orange FIPG deng mentioned is called # 1281 Seal Packing, which is for use on drivelines. In theory the black silicone will work as well on almost anything. The difference in colour and formulation is to distinguish its resistance to the fluid, temperature, or vapour in its intended environment. I have an unopened tube of 1281 that you can take on Saturday, tmontague.
That's very kind of you, Lux. What a great site we have here.
SUPER bannned
Drives: Stock Join Date: Aug 2010
I'm not mechanic, so no idea on how to rebuild engines. but Thank you and nice to have you here
Enthusiast
Drives: 07 Yaris HB 1.3 (EU) Join Date: Nov 2014
How much to 62100 Greece?
Cheers, George. |
![]() ![]() Drives: Yaris 3-door Join Date: Aug 2009
I would be happy to take some FIPG. Yaris & Echo has leaking timing covers, sisters 3.5 Camry timing cover leaks too. Are you shipping to California?
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Toyota: The Most American Car Company | Kal-El | Off-topic / Other Cars / Everything else Discussions | 18 | 07-10-2009 12:01 AM |
| Response from Toyota | Driver | New YARIS Purchase Forum | 22 | 09-04-2006 07:44 PM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
