Old 11-12-2017, 09:31 PM   #1
sigsauer13
Drives: 08 yaris sedan
is it just me or is my car too loud?
new to the forum...so i have owned this 08 yaris base model for 1 year now. bought it last year and got a fantastic deal on it. only had 9k miles on it when i bought it last year. i've noticed now that over the last 4 oil changes it's become rather loud. it's louder than it used to be when i first bought it. especially with the a/c turned on. anything i can do to make it run a lil bit quieter? everything is stock. there isn't anything wrong with the cat. no leaks, nothing that i can see. no performance issues from the day i bought it. it's just louder
sigsauer13 is offline   Reply With Quote
Old 11-13-2017, 12:29 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Turn the volume down.
On some seriousness, what's loud? Engine?
AC compressor makes noise. It's normal.
Failing water pump maybe? Or a squeaking belt?
Old 11-13-2017, 10:02 AM   #3
dogsridewith
Drives: 2007 2-door hatchback
Toyota yaris loud road noise tires intake exhaust doors
It is a loud car model. (Hatchback is...maybe your sedan less so w/ smaller doors.) Are tires original? Tires can make a lot of noise. I put quiet ones on everything now. Then you can hear pavement texture instead of tire tread. Which is cool, so turn off all infotainment and enjoy the car sounds. (Original intake and exhaust is very cool.)
Could be effect of paying attention to something once it is first noticed.
Old 11-13-2017, 11:40 AM   #4
bronsin
bronsin's Avatar
Heres a suggestion. Get a large rag and start the engine. Before the tailpipe gets too hot, wad the rag up and seal the end of the tailpipe with it. Do you feel pressure? When you remove the rag does the pent up gas pop out with a rush? Or is there no sensation of pressure at all? If not then theres a hole in your exhaust system somewhere.
This is a quick and dirty way to test the exhaust system for leaks in general.
Old 11-13-2017, 01:31 PM   #5
IllusionX
Lol reminds me of this.
https://youtu.be/0qFW8aRtr60
Old 11-14-2017, 12:21 PM   #6
bronsin
bronsin's Avatar
I could see that coming....
Old 11-15-2017, 10:04 PM   #7
sigsauer13
have had my entire exhaust system looked at, no leaks. it's the engine that's loud. just being on, sitting idle in the dw it just sounds a good bit louder than it used to. even with the compressr off
Old 11-16-2017, 01:22 AM   #8
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Only 9K on a 2008 car? How many miles since? Engines often get louder as they break in. So maybe that is what is happening here. I noticed an increase in volume with my car as well. But what level of sound are we talking about? Slight increase? Or get out the earplugs level? If the former I wouldn't worry about it.
Also what weight oil are you running? I can definitely hear a difference between 5W-30 and 5W-20. (20 being louder). 5W-30 is the spec'd weight for the 1NZ-FE but the dummies at the dealer twice put 5W-20 in it during the free ToyotaCare maintenance.
Old 11-16-2017, 04:25 AM   #9
zoidberg444
zoidberg444's Avatar
I've always found the Yaris pretty loud. They scrimped on the sound deadening compared to more expensive less fuel efficient cars or even other vehicles made by different manufacturers in the same class like the Honda Jazz. The engine in my Yaris is pretty unrefined too (the 3 cylinder model) its noisier than 4 cylinder engines.
One thing that might be making it a little louder is your tyres. I had 2 worn out old chinese tyres on the back. I had them replaced with new Falkens on all 4 wheels just before my euro road trip and it really seemed to quieten the car right down.
UK to Nordkapp in a Yaris
Old 11-17-2017, 01:56 PM   #10
sigsauer13
it's got 24k right now. been using 5-30 but will go to 5-20 once the temp dips. loudness is audible when you're paying attention to it. otherwise it's not as noticeable. since it's almost at 25k, do i need to do a tune up on it to see if it helps reduce the noise? i got a great deal on the car. lady traded it in with 9k miles and i bought it the day they put it out on the lot. she took really good care of it. EVERYTHING inside and out looked brand new
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 05:19 AM
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 09:01 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 10:03 AM
