![]() ![]() Drives: Yaris Join Date: Oct 2017
Sort of successfully finished my PKE install!
PKE - Passive Keyless Entry System:
https://rover.ebay.com/rover/0/0/0?m...2F332460280380 There are similar products on Amazon for double the cost but you will probably get better customer service. So I say sort of finished because my remote start feature doesn't work properly. It will start the car but it stalls right away and I can hear the starter grinding the flywheel before it stalls. But other wise it's trueley keyless go. I have unplugged the ignition harness and cut a spare key I had to prevent it from locking. ![]() ![]() ![]() ![]() Used a plug that Inhad left over from the power window install and worked out perfectly! |
That is awesome! Thanks for posting.
My 08 has a command start (aftermarket) and keyless entry. I cannot get used to putting the key in the ignition and as soon as I touch the break and prepare to select a gear, it shuts off and locks the doors on me. I gets me EVERY time!
Bought some Toyota logo decals for keyfob, looks hella OEM haha
![]() Sent from my iPhone using Tapatalk Pro |
Drives: Yaris XP9 1.33 2008 pre-faceli Join Date: Jan 2018
Wow I'm trying to attempt the same, could you please send me some pictures of the wiring? Would be super kind! :)
I did not take any unfortunately. I was using the DIY remote start guide for all the wiring and pictures.
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| ))) Tein Super Compact coilover install tips ((( | aucorium | DIY / Maintenance / Service | 4 | 10-25-2011 12:42 AM |
| Micro Image underpanel install DIY | cali yaris | DIY / Maintenance / Service | 27 | 08-29-2009 09:48 PM |
| Non-Yaris Audio install help needed | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 08-17-2009 11:47 AM |
| Finished my install ........Finally | DARKYARIS | In Car Entertainment + Electronics (audio / video / alarm) | 25 | 05-13-2007 03:52 AM |
