![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Ichaba 10 mm wheel spacer question/s
I just received these(specifically for yaris)
I read this thread and there seems to be a issues regarding stud length and if washers are needed. Not ichaba but penguin thread.. http://www.yarisworld.com/forums/showthread.php?t=18092 The studs that came with package are 57-58mm in length. Getting the drum off is easy peasy but I want to know am I good to go with these length studs and if I should get washers? PIC of one set of rear spacers... ![]() Basically I dont want to get everything disassembled to find out something is not quite proper/missing. |
やりすぎだ~
If the length of the threads of the new stud is 10mm longer than the original one then you're good.
The new stud length should at least make up for the thickness of the spacer. Dont confuse hub spacers with wheel spacers. |
#3 | |
Should be good to go. |
| Rear Wheel Spacer Help 10mm | pinhead123 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 11-25-2017 09:45 PM |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| Longer wheel studs for 5mm spacer? | Captain Slow | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 02-09-2013 10:35 PM |
| FS: Sparco Wheel, Quick Release, Momo Spacer | Focus_Sh1ft | Items for Sale by private party | 18 | 04-27-2011 12:36 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
