#19 |
![]() Drives: 2008 Yaris hatchback Join Date: Nov 2017
im having the same issue and its getting scary driving on the freeway. I went to a Firestone and they checked shocks/struts which were okay. They put on new tires and did an alignment. The tires are Champion Fuel Fighter BL 185/60r15. Are these okay tires?
With that wandering/floating feeling is there any chance the car can just flip over? It certainly feels like it when the freeway veers right. |
#20 |
![]() ![]() ![]() ![]() Join Date: Feb 2010
If your car does not have one already, get a rear sway bar installed first, then consider new tires if still needed..... they are easy to install. just do a diy rear sway bar search on here for more info.
#21 | |
Sent from my SM-G930W8 using Tapatalk |
#22 |
[QUOTE=IllusionX;806759]I don't think I've ever mentioned before. Be careful when just adding a rear sway bar to a stock car. The car will oversteer more in corners.
Be careful at first but don't worry about it....i added one to my Yaris and on the flip side i would probably be concerned about how it handles if someone were to remove the sway bar without telling me.. |
#23 |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Just add a few bags of sand in the spare wheel well. With an extra 80-100lbs or so on the rear axle you'll be just fine driving up to 80mph. With 150lbs on the hitch and 100lbs in the rear I got up to 100mph before the car felt a little float with a (driver) single occupancy.
| steering wheel slight vibration high speed??? | marcus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 10-01-2012 06:36 PM |
| HIGH SPEED YARIS CRASH.... | ROCKLAND TOYOTA | Photo-Video-Media Gallery | 23 | 03-10-2012 08:59 AM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| Have I mentioned how much I hate Speed sensors? | staticorex | General Yaris / Vitz Discussion | 13 | 05-28-2009 04:04 PM |
| Six speed | Snyprwlf47 | Performance Modifications | 16 | 11-24-2008 09:04 PM |
