Old 01-03-2018, 11:52 AM   #1
duggy16v
Drives: Toyota Yaris 2NZ-FE
2007 Yaris engine swap - 2NZ-FE to 1NZ-FE
Hello all. This is my first post. I am fairly new to Toyota. Any help will be appreciated.
Okay, existing 2NZ engine had turned a bearing and 2 conrods came through the crankcase. I would like to replace the entire engine with a 1NZ. Is this possible ?
Here in South Africa, we have 2 versions of the Yaris engine, the 1.3 vvti and the 1.5 vvti. I can get the 1.5 for a good price. What I'm afraid of is will my existing gearbox work ? Will the existing ECU work as well ? I have also installed a new clutch kit on the 2NZ before the damage. Will this clutch kit work on the 1NZ ? Will the engine mountings be the same ?
Any response would be appreciated.
Thank you.
duggy16v is offline   Reply With Quote
Old 01-03-2018, 05:45 PM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Thank you.
Yes the gearbox and everything else will work. The only unknown is if the 2nz ecm can run the 1nz
ArmstrongRacing is offline   Reply With Quote
Old 01-04-2018, 12:58 AM   #3
duggy16v
Thanks. I will be using old ECU just to start car. Thereafter will remap and dyno tune. Is this possible ? The ECU doesn't know that the engine will now be a 1.5.
Old 01-06-2018, 08:35 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Everything should work out fine. Those engines are nearly identical and should also share the same sensors.
2007 Yaris Engine Swap tmtab8588 Performance Modifications 2 12-29-2017 01:32 AM
Yaris 2nz engine upgrade yarisgravel UK 0 10-28-2015 06:10 AM
03 Yaris 1.0 VVti Engine Swap, URGENT help needed. philwept_33 DIY / Maintenance / Service 1 05-15-2009 12:15 PM
