Old 01-14-2018, 12:21 AM   #1
Drummy
Drummy's Avatar
Drives: 2008 Toyota Yaris Hatch
Part Recommendations
Looking for part recommendations to give me a little boost to my '08 Yaris. I've currently got nothing. Looking for a quick shift or short shift kit. Anything to provide a horsepower boost would be good too.
Drummy is offline   Reply With Quote
Old 01-14-2018, 10:35 AM   #2
3cyltrbo
Hello
As others will surely chime in, some of the best bang for buck mods are actually in the handling department.
As for power adders, on this current yaris and my previous Echo... I found a full set of lightweight pulleys and an exhaust manifold ("header"), in conjunction with some form of intake mods, to give a discernible difference.
Some (including me) have also done a throttle body swap from a Corolla.
I bought some "short shift" accessories from MicroImageOnline while that was still operating, and although they've closed their website..you might still find some stuff from them (or others) on Ebay for short shifting adapters
Will
3cyltrbo is offline   Reply With Quote
Old 01-14-2018, 04:48 PM   #3
SirDigby
Drives: 2007 yaris 3 door
trd makes a shifter kit. there is a few other brands out there. a 1zz-fe Throttle body is an excellent upgrade. porting the manifold to match the throttle body and modifying the angles also is inexpensive and beneficial. (i like doing this!)
rear sway bar is good, as the car is lacking one.
after that you are looking at spending larger amounts of money....
Old 01-14-2018, 05:35 PM   #4
Drummy
Drummy's Avatar
Just purchased a Quick Shift kit from Micro Image on eBay. Currently at work. It may not say that I am online but I am looking.
Where would I be able to get a good Rear Sway and throttle body? Not looking for over the top prices but something that's going to perform well for the price. Looking on eBay I see a lot of pre owned throttle bodies but my concern with those is that they may not function as well as I'd like or at all. Any advice you could give?
Old 01-14-2018, 11:46 PM   #5
3cyltrbo
UltraRacing / Cusco / Tanabe / TRD, all make rear end stuff.
As for the pre-owned throttle body, if you look closely enough you'll find one soo cheap that its an easy gamble (in-case it doesn't work). In fact, I bet you could call around to local scrapyards and find one (ie: from a wrecked Corolla) close by
Old 01-15-2018, 10:51 PM   #6
SirDigby
yeah. local pull-and-save or junkyard. you should not pay more than $40 for one.
i have a whiteline swaybar. they are usually around $100 regardless of the brand.
you should at least port the manifold to match the throttle body diameter when you do the swap.
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 01:01 AM
AFE Intake part - were to locate Darwin84020 Performance Modifications 1 03-26-2017 05:35 PM
DIY - Carbon fiber wrapping Brian Wash, Wax, Detailing, Exterior Repairs 15 07-10-2016 01:34 PM
Evap canister part number for 2007 yaris sedan baseballfan416 DIY / Maintenance / Service 4 04-26-2015 12:16 AM
Buying One Specific Part.... hasher22 General Yaris / Vitz Discussion 2 08-26-2006 10:57 AM
