Old 02-14-2018, 10:22 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Arrow König Dial-In wheel review
I know there is some mis-information out there on the quality of Konig wheels, So I wrote this review to show the truth.
http://www.armstrongfamilyblog.com/a...-season-review
ArmstrongRacing is offline   Reply With Quote
Old 02-15-2018, 11:17 AM   #2
tmontague
tmontague's Avatar
Solid review, glad the rims are working out for you. I also really enjoyed mine for DD'r use and their weight was unbelievable.
I should note that both my dial-ins and my now hypergram's both had very poor balancing my the factory in all 4 rims in both types.
Minimal wheel weights were able to correct this and I've had no issues at high speeds but the tire tech complained and said they were brutal with just the rim and he's never seen such bad balacing before.
Now for the price of the rims I don't mind and since it can be easily corrected it isn't really an issue. But this is important to note as some people may be alarmed when they get their new Konig's. You get what you pay for and these are great rims for the price but don't expect precision manufacturing from a sub $1000 rim
Old 02-19-2018, 07:50 PM   #3
ArmstrongRacing
Data doesn't lie
Did your "tire tech" spin the wheels bare on the machine before installing the tire? The wheel balancing is perfect, the issue of imbalance comes from how the tire is installed on the wheel.
Are the paint marks on your tires matched up to the valve stem location on the wheel? If so, then again if you install a "used" tire onto the wheel the tires balance has changed from wear.
Also, if minimal weights(less than 2oz) were used to balance the wheel/tire assembly then you have a solid match.
kong dial in, wheels
XuJi Leather steering wheel cover review fgordi Cosmetic Modifications (Exterior/Interior) 0 03-19-2017 02:33 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
