Old 02-20-2015, 02:18 AM   #1
blktiger60
blktiger60's Avatar
Drives: `08 HB S
Projector headlight opinions
Are these any good?
http://www.carid.com/2008-toyota-yar...-12131502.html
What about these?
http://www.carid.com/2008-toyota-yar...ts-439957.html
Thinking about changing out the oem's.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 02-20-2015, 08:31 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Bottom one is for Sedan.
Old 02-20-2015, 05:00 PM   #3
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
The link in the first one, is quite common here for drop in projector headlight. Simply put, it is form over function. It looks great on the car, but the output and light quality is terrible.
Check out my Build thread:
Old 02-20-2015, 05:48 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
^ yes. I had some similar before and threw HIDs in them. The light output was "better" but I didn't like the cutoff on the right being super high. Didn't want to blind drivers as I passed or drove in the left lane.
Old 02-21-2015, 01:19 AM   #5
blktiger60
blktiger60's Avatar
Drives: `08 HB S
Right. must have posted the wrong link
Do they put out as much light as the oems. That's my only question. I cant find the lumens info. Don't want to to do HID, and I like the way the spec-d's look.
Old 02-21-2015, 02:09 AM   #6
ezhacker1
ezhacker1's Avatar
no where near as bright as OEM, or evenly lit, there will be hot spots and the cut off is weird, i had to flatten it out and still no a sharp cut off. They look amazing but perform subpar.
Old 02-21-2015, 02:35 AM   #7
blktiger60
blktiger60's Avatar
Drives: `08 HB S
Do they accept different bulbs to make them brighter or are you just stuck with whats in them?
EDIT: Apparently, the bulbs can be upgraded http://www.protuninglab.com/xehidkit06to.html
Old 02-21-2015, 02:48 AM   #8
ezhacker1
ezhacker1's Avatar
You just said you dont want to do HID tho. I have HID in mine, and it does help the light to be brighter (duh) but the reflector bowl really wasnt design for it, so hotspots are even worse.
Old 03-04-2018, 10:46 PM   #9
blktiger60
blktiger60's Avatar
Drives: `08 HB S
I opted for a 12" LED light bar and LED replacement bulbs. Mounted the bar using the license plate bolts.
Plenty of nice clean daylight (4500K) illumination down the road now.
Old 03-04-2018, 11:03 PM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Or get proper HID projectors and you wont need that nonsense
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-13-2018, 05:57 AM   #11
Whiplash
Drives: 2009 Yaris 4DR
Get some HID's which cost more than his car is worth, that's some good advice...
Whiplash is offline   Reply With Quote
I NEED Boost... Opinions puh-lease Focus_Sh1ft Forced Induction Forum 551 02-08-2013 05:55 PM
rim/coilover opinions ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-12-2010 07:02 PM
headlight opinions whiteghetto DIY / Maintenance / Service 1 02-08-2010 06:32 PM
New Owner's Opinions... guzziknight New YARIS Purchase Forum 18 06-21-2009 11:52 PM
Building a New Exhaust... Need some opinions. DTM_Yaris Performance Modifications 21 12-28-2006 08:42 PM
