![]() Drives: yairs 2010 Join Date: Jan 2018
Low idle on Yaris 2010
I guy a ran a diagnostic test on my car and they is no error messages. Please can some help me with a low idle on my car it is sitting around 300 reeves. I think it supposed to be around 500?
durban? where is that?
plugged air box filter? clean air filter? clean MAF? clean injectors? if all else fails, there is an idle adjust screw. |
Durban is in South Africa, Is this Yaris a diesel or gas version?
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
For the 1.5L 1NZ-FE engine Yaris the official idle speeds are 550-650 for the M/T and 650-750 for the auto transmission. Rather unlikely that you have the 1.5L engine in ZA but it's a good baseline, and 300 rpm is way too low for any 4 cylinder engine. Most modern engines have electrically controlled throttle bodies so you can't adjust the idle up and down with cable tension like in the old cable operated TB's. If you're not getting and codes or pending codes I'd start with checking the air filer and cleaning the MAF sensor with brake cleaner to see if that improves things.
idle rpm revolutions per minute Toyota Yaris OBD II connector frequency multimeter
Maybe your idle is actually 600 rpm, and the 300 reported is due to the "diagnostic" missing a factor of 2. (I used the frequency setting of a multi-meter to find that my manual trans 1NZ-FE stays very close to 600 rpm idle once warm. The rpm pin on the OBD II connector--Toyota designates this "DLC3"--makes 2 pulses per engine revolution.)
How I know the idle is low is when I am driving the car switching of
| (Help) Me Jealous? Friend buys 2010 Yaris. | *MAD DOG* | New YARIS Purchase Forum | 16 | 09-26-2010 10:22 PM |
| Vital info for prospective 2010 Yaris buyers | YarisOwnersDad | New YARIS Purchase Forum | 22 | 05-19-2010 09:16 PM |
| 2010 Yaris Idle Stop Function ? | Nu18F | New YARIS Purchase Forum | 6 | 02-12-2009 06:46 PM |
