Old 03-29-2018, 02:34 AM   #1
Riteshb
Drives: yairs 2010
Low idle on Yaris 2010
I guy a ran a diagnostic test on my car and they is no error messages. Please can some help me with a low idle on my car it is sitting around 300 reeves. I think it supposed to be around 500?
Riteshb is offline   Reply With Quote
Old 03-31-2018, 12:47 PM   #2
SirDigby
Drives: 2007 yaris 3 door
durban? where is that?
plugged air box filter? clean air filter? clean MAF? clean injectors?
if all else fails, there is an idle adjust screw.
Old 03-31-2018, 03:33 PM   #3
ex-x-fire
Durban is in South Africa, Is this Yaris a diesel or gas version?
Old 03-31-2018, 04:49 PM   #4
B.B._07
Drives: 07 5dr
For the 1.5L 1NZ-FE engine Yaris the official idle speeds are 550-650 for the M/T and 650-750 for the auto transmission. Rather unlikely that you have the 1.5L engine in ZA but it's a good baseline, and 300 rpm is way too low for any 4 cylinder engine. Most modern engines have electrically controlled throttle bodies so you can't adjust the idle up and down with cable tension like in the old cable operated TB's. If you're not getting and codes or pending codes I'd start with checking the air filer and cleaning the MAF sensor with brake cleaner to see if that improves things.
Old 04-01-2018, 10:31 AM   #5
dogsridewith
Drives: 2007 2-door hatchback
idle rpm revolutions per minute Toyota Yaris OBD II connector frequency multimeter
Maybe your idle is actually 600 rpm, and the 300 reported is due to the "diagnostic" missing a factor of 2. (I used the frequency setting of a multi-meter to find that my manual trans 1NZ-FE stays very close to 600 rpm idle once warm. The rpm pin on the OBD II connector--Toyota designates this "DLC3"--makes 2 pulses per engine revolution.)
Old 04-03-2018, 02:10 AM   #6
Riteshb
Drives: yairs 2010
How I know the idle is low is when I am driving the car switching of
(Help) Me Jealous? Friend buys 2010 Yaris. *MAD DOG* New YARIS Purchase Forum 16 09-26-2010 10:22 PM
Vital info for prospective 2010 Yaris buyers YarisOwnersDad New YARIS Purchase Forum 22 05-19-2010 09:16 PM
2010 Yaris Idle Stop Function ? Nu18F New YARIS Purchase Forum 6 02-12-2009 06:46 PM
