Changing AC pressure sensor
Hi folks,
my AC sometimes takes 5-10 minutes before it starts blowing cool air (but it is like 1 case out of 5). Local AC service center inspected the system, found nothing extraordinary (they measured the pressures - all OK, they had to add some "freon" as well but just a little). But they do not have TechStream so they could not check the data there. But I do have TechStream so I noticed that the readings from the pressure sensor are a bit erratic whenever the AC problem happens. So I am going to change that little thing.I have read probably all the topics around it here on yarisworld - guys you are awesome! Now I know I have to get myself one piece of 499000-7141. The last thing is the change itself. I have learnt on the internet that "most cars do have a ball valve on that sensor so it can be replaced without evacuating the AC system". Is it also the case for Yaris? (2007 5-door 2SZFE 1.3 64kW) Or do I need to drop by the local AC shop one more time to do the change for me? Or if I am fast enough, can I replace the sensors with just a little bit of hisssssssing from the line that may have no impact on the functionality, especially when it was recently topped up? Thank you in advance, lads! |
I had to change my pressure sensor last year (1NZ). Freon was evacuated as mechanic could find no indication that system is protected by a valve.
Luckily I have peeked below the hood once again... to find out that my sensor is DENSO 499000-7880, not 7141. According to other threads this is oil pressure sensor... but some shops do sell it as AC fluid pressure sensor. What a mess....
edit: and according to some Denso servicing instructions I found... the 7141 and 7880 are interchangeable. Last edited by komichal; 05-09-2018 at 02:50 AM. |
| DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS | auxmike | DIY / Maintenance / Service | 50 | 12-10-2024 12:39 PM |
| Help! A/C low pressure sensor..jumper? | marcus | Photo-Video-Media Gallery | 12 | 07-18-2012 05:50 PM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 04:46 PM |
