Old 03-25-2018, 09:32 PM   #37
fredovvti
Drives: Yaris 07 HB
Thank you guys for the help, i will imput my updates.
Thanks very much!!
Sent from my SM-N950F using Tapatalk
fredovvti is offline   Reply With Quote
Old 03-25-2018, 10:39 PM   #38
David C
Drives: White '07 3dr LB
Originally Posted by govtec View Post
What year is your car? I accidentally ordered a pair of post facelift JDM HID headlights that I will sell soon here in the states once the weather warms up and I install the pre facelift headlight in my car. The only thing that is missing is the ballast which you can get off of ebay easily. I can definitely sell it to you if you want to wait little bit.
Mines a 2007 HB.
I installed LED H4 bulbs and Morimoto XB fog lights two weeks ago and now I'm doing a lot better on lighting. Thanks for the offer tho.
Old 04-01-2018, 02:19 PM   #39
fredovvti
Drives: Yaris 07 HB
Originally Posted by enviri View Post
USDM lexus ballasts work well
What model that you use? I buy a pair but it came with a diferent conector.
Old 04-01-2018, 05:29 PM   #40
enviri
enviri's Avatar
Drives: 2010 Yaris
ground cable not needed.
Old 04-02-2018, 08:42 AM   #41
fredovvti
Drives: Yaris 07 HB
Thats the one I order, but seen your videos the cover of the ballast from my headlights are much bigger. I put this one but they are small.
In the pictures, that is the ballast that came in the headlight.
Old 04-02-2018, 01:40 PM   #42
enviri
enviri's Avatar
Drives: 2010 Yaris
if that's the case you might have to stick with those or maybe look into whatever the prius used in 2006.
85967-50020 is used in
Japan 08/2000-07/2006 TOYOTA CELSIOR UCF3* 81-01: HEADLAMP
N. America 08/2000-07/2006 LEXUS LS430 UCF30 81-01: HEADLAMP
Old 04-08-2018, 10:11 PM   #43
fredovvti
Drives: Yaris 07 HB
At last, my headlights are working. Here are photos of the outpug. The firts are lows, the second are the highs. I tell you, is the best output I see.
Old 04-08-2018, 10:22 PM   #44
enviri
enviri's Avatar
Drives: 2010 Yaris
welcome to the jdm club :P
Old 04-08-2018, 11:06 PM   #45
fredovvti
Drives: Yaris 07 HB
Thank you all guys for your help!!!
Old 05-06-2018, 11:31 PM   #46
govtec
Hey Enviri,
I just got to installing my JDM headlights today...After taking the passenger side headlight out, I find that I ordered the wrong female 3 prong plug! Should have been a male 3 prong plug! The other thing I realized is that after accounting for all of the harnesses, I'm left with 2 unplugged harnesses and I remember your vids only had the brown harness that was left unplugged. So then I realized that I'm missing the parking light plug altogether. This leads me to 3 questions I have for you...
1) What is the part number that I need to order that will plug into the parking light harness on the car side?...From your video's I see that it is a 2 prong male connector.
2) Why do I need the extension cable again? I don't see where it is needed as all of the wires and harnesses are tucked into the big black HID cap housing.
3) Can you confirm the exact ground wire that I'm tapping into in post # 20 in the last picture?...Is it the HID wire, parking light wire or high beam?
Thanks
https://drive.google.com/open?id=1_j...gNcYIvWZ-ZvY4d
https://drive.google.com/open?id=17X...OPSm9RR9qe6-80
https://drive.google.com/open?id=1Tm...kvrmZNCh53sQ02
govtec is offline   Reply With Quote
Old 05-07-2018, 08:51 AM   #47
enviri
enviri's Avatar
Drives: 2010 Yaris
lol woops.
1) ebay or amazon.
2) extension? i dont remember? lol
3) ground is definately parking light.
2 unused plugs...i have to check again, only unused plugs i have are parking light plug on each side if i remember right...which i believe is that brown connector on your third pic.
Old 05-07-2018, 02:06 PM   #48
govtec
lol woops.
1) ebay or amazon.
1) I don't think we're talking the same thing. Look at pic # 4 of post # 20. The t10/194 plug does not look anything like pic # 4 which has Toyota specific plug housing.
Old 05-07-2018, 09:17 PM   #49
enviri
enviri's Avatar
Drives: 2010 Yaris
should be parking light connection, connected to that free brown female plug. the 194/t10 male connects to that.
Old 05-07-2018, 09:41 PM   #50
govtec
Your video's showed the brown one was unplugged. I'm looking for this 2 prong male grey plug that I see was spliced to the 4 prong plug as well as the the ground wire.
See pic of what I'm referring to...
File Type: jpg Screen Shot 2018-05-07 at 9.30.18 PM copy.jpg (76.1 KB, 205 views)
Old 05-07-2018, 10:50 PM   #51
enviri
enviri's Avatar
Drives: 2010 Yaris
its the other one of the 2 t10 connectors for the stock headlight...the side marker light.
Old 05-07-2018, 11:10 PM   #52
govtec
Pic # 1 below show's how the 2 ends of my 194/t10 parking light extension cable that I ordered. Is this the right one?
Pic # 2 shows the 2 plugs that I have left to use and none of them will fit 194/t10 cable from pic # 1.
Old 05-08-2018, 04:04 PM   #53
enviri
enviri's Avatar
Drives: 2010 Yaris
yeah both of those unused plugs are for parklight bulbs. i used the one to the right, the brown one i use as a hood lamp.
i assume you still have this? it may still be connected to your headlight, next to your winker bulb.
Old 05-08-2018, 07:24 PM   #54
govtec
I see what you did. I'll have to wait until the weekend since the headlights are at my parents house.
Do I cut-off the other end of 3 so I can splice the wires to the 4 prong and parking light? Thanks
FS: 2012 Yaris oem headlight projector retrofit ucsmfu Items for Sale by private party 4 11-01-2016 10:28 PM
How can i get the OEM Headlight Stalk with FOG switch to work murtaza.shahid DIY / Maintenance / Service 0 11-22-2014 06:30 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal 03Z33 Items for Sale by private party 30 01-02-2009 06:55 PM
DIY - JDM RS style REPLICA tails kurokoma-kun DIY / Maintenance / Service 0 10-21-2008 02:56 PM
