Old 08-15-2018, 03:34 PM   #1
YodaBird
Drives: Gray
Clean wear middle of rim ?
How can I clean up what appears to be burn on the middle part of the rim as seen in this image ?
YodaBird is offline   Reply With Quote
Old 08-17-2018, 02:19 AM   #2
SUPA DUPA 1
Drives: 08 LIFTBACK & 2015 5d SE
I would start with a rag and simple green. Slowly work up from there. You shouldn't have to go above a green scotchbrite pad. one thing that i know for sure is if that is the hub mating surface you "DO NOT" want to be removing material without a good mill.
SUPA DUPA 1 is offline   Reply With Quote
Old 08-17-2018, 10:46 PM   #3
YodaBird
Drives: Gray
Good mill ?
Old 08-18-2018, 09:03 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
good mill = a good milling machine.
Yodabird, is there a reason you need to clean that particular area?
Old 08-19-2018, 11:18 PM   #5
YodaBird
Drives: Gray
@yarisugi
I want too smooth it out, make it appear a little better then scratch marks as it looks now.
Old 08-20-2018, 07:59 AM   #6
dogsridewith
Drives: 2007 2-door hatchback
those aren't scratches...they're normal marks by the cutting tool that finished that area of the rim.
Old 08-20-2018, 09:30 AM   #7
YodaBird
Drives: Gray
@dogsridewith, not those areas; the other areas which look like splotches which are worn out.
Old 08-20-2018, 02:24 PM   #8
Is that the hub side or face of the wheel? That is one shitty picture.
Old 08-21-2018, 12:03 AM   #9
YodaBird
Drives: Gray
It's a close up of the face, specifically where on the rim I want to draw attention too.
Uneven Tire Tread Wear? turblown Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-11-2017 09:09 PM
Is getting the rim repaired worth it? nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 10-10-2014 04:22 AM
Rim 13" or 14" Yaris Hatchback 2008 Bearmantle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-19-2013 12:11 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
