Paint Code for Alloy Wheels? And Wheel Repaint
Does anyone know the OEM paint code for the alloy wheels on the Yaris RS. Figured I'd paint these while I'm doing my respray.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-17-2018 at 11:46 AM. |
I don't believe wheels, any manufacturer, has published paint codes. My searches have shown that there are a couple Duplicolor that have been claimed to be exact match, or damn close.
You could take this opportunity to do something funky fresh. Sent from my Elite_5_5_Octa using Tapatalk
#3 | |
BTY1602
Awesome. Thanks!
Ordered about 1/2L of the paint - 2K urethane. Should be here by Monday. I have lots of clear coat. Hoping to be done by mid next week.
Wheels are degreased - several times - small scratches sanded out, small dings filled with filler. A couple more wet sand sessions and on goes the primer, base and clear. All I have to do when they're done is find someone who will guarantee that they won't scratch them up mounting and balancing the tires. Wheels are almost ready for primer. ![]() This is the closest I'll get to a lowered Yaris for a while. 14" winter rims and tires. Hoping to have the alloys painted and back on the car late next week. Away for a few days so won't be able to get at it as soon as my paint gets in.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-17-2018 at 03:09 PM. |
What paint?
I'm so boring. Just the 1C8 Lunar Mist. Should have gone with a black metallic. And satin black racing stripes.
^^^ Please no more black wheels!
Haha. No, there won't be any black wheels on my Yaris. For interest sake, if you were going to repaint yours, would you opt for stock silver, or another color? I welcome anyone to state their preferred wheel cover, if so inclined.
Stock silver would be my preference with those wheels.
This will be a must see.
Base Coat
Will post pics of clear coat later. ![]() 2 Coats of clear. One more left in about 1/2 hour. ![]() Final Clear on one wheel. They're all about the same.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-22-2018 at 09:47 AM. |
They look outstanding. You really know how to paint!
Thanks Kimona! There is surprising little orange peel. Low pressure, slightly narrower spray pattern and wet coats seems to work best with my gun. I didn't paint the barrels. I did sand them and I'll paint them flat black with a brush. Can't wait to get them on the car. 2 days baking in the sun, then Friday I'm taking them to a shop that installs new aftermarket wheels on new trucks for the dealers. They charge the same as any other garage.
Great. You want a competent installer with the proper equipment, so you don't scratch your newly painted wheels. Make sure the paint is hard. Don't rush it.
Absolutely. I was hoping for a warm sunny day today so I could let them bake. Unfortunately, it's calling for showers. Tomorrow looks better though.
| Testosterone: The New Synthetic Oil | bronsin | Off-topic / Other Cars / Everything else Discussions | 23 | 12-15-2013 06:02 PM |
| DIY: Painting Engine Cover | frownonfun | DIY / Maintenance / Service | 12 | 11-30-2013 11:07 PM |
| Stripping Paint Without Sanding | CrystalJean | DIY / Maintenance / Service | 1 | 10-06-2012 04:06 PM |
| 12/20/08 Buddy Club USA 5th Anniversary Clearance SALE | DuckinOut | California | 3 | 12-18-2008 12:25 AM |
