Old 08-15-2018, 05:04 AM   #1
zani
Drives: Yaris
Passenger door lock actuator - not enough power?
Hi all,
I've been backwards and fowards with front passenger door causing problems with the car not unlocking on keyfob.
(Car is a 5 door 1.0 GS 2001, right hand drive)
I have replaced the lock mechanism, and bought a new actuator.
- All doors lock, but then none will unlock.
- If I unplug passenger door actuator, the remaining 3 doors and boot lock and unlock OK
- If I remove the passenger door actuator from the lock mechanism and plug it in on its own, all doors lock and unlock ok (including the passenger actuator - can see plastic arms moving to lock and unlock position)
At a guess, the actuator isn't getting enogh power? The plastic arm to tell the actuator it is "locked" doesn't appear to be moving all the way over? So the car thinks it is always unlocked.
What could case this? Bad earth? Bad central locking module?
Where do I start looking?
Many thanks!!!
zani is offline   Reply With Quote
Old 08-16-2018, 10:23 AM   #2
Dfteam
Drives: Yaris 1.0 sol 03
I've a problem like your. Do you know where is located central locking unit/module?
Inviato dal mio VTR-L09 utilizzando Tapatalk
Dfteam is offline   Reply With Quote
Old 08-22-2018, 11:26 AM   #3
zani
Drives: Yaris
No, is this the problem?
Have you fixed your issue?
Regards
Mark
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 04:36 AM
Passenger Power Window replacement AMOKS DIY / Maintenance / Service 0 03-15-2016 10:29 PM
OEM Power Locks wiring in Base Model MedMantle DIY / Maintenance / Service 4 03-11-2016 05:47 PM
Installation of original power windows and locks in Yaris lantis DIY / Maintenance / Service 4 02-25-2012 02:38 PM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 08:22 PM
