Old 08-29-2018, 07:02 AM   #1
sunsanvil
Drives: 2018 LE 5DR A4
2007 rotting at rear a-arm mounts
While getting our 2007's exhaust looked at a few weeks ago they found the unibody was rusting through where the rear axle "arms" attach (inside mounts, both sides, were the worst). Quite serious (we got a second option to confirm).
Noteworthy is that the car had absolutely NO rust anywhere else so this really came as a shock. Even more interesting is that the garage had seen another 07 that same week with the exact same issue.
I'm thinking design defect, ineffective dip, or bad welding in that one spot that year.
Particularly if you are in the rust belt, but even if you are not, this should be something to keep your eye on.
sunsanvil is offline   Reply With Quote
Old 08-29-2018, 07:20 AM   #2
ex-x-fire
Yeah, someone had that problem a year or two ago on here. I started using Fluid Film to stop rust.
Filling rear arm bushing with polyurethane. Caramanos2000 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-05-2015 10:55 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
