Old 09-18-2018, 08:28 PM   #1
thetoyotaman
Drives: 2009 Yaris
Getting ready for winter
Found a set of used 1st gen 14 inch prius wheels. Ordered a set of Hankook studded tires in a 175/70/14. Planning on getting the wheels blasted and then painting or powdercoating. Chose the tire after reading this article. There are so many conflicting reports on snows that it's hard to make a choice but the Nokian 8's I've been using were not up to Nokian experiences Ive had before and I used some Hankooks on a truck last year that worked well so here goes.
http://www.skstuds.ca/2017/10/11/ent.../#comment-2105
thetoyotaman is offline   Reply With Quote
Old 12-08-2018, 02:00 PM   #2
thetoyotaman
Drives: 2009 Yaris
Winter update. Ended up bead blasting the rims with glass beads myself at a friends shop. Primed with self etching primer and used wheel paint/wheel clear coat. Wouldn't do the clear coat again. Doesn't lay down as well. Paint did great though. Installed the Hankooks and very pleased. Also purchased Denso tire sensors that are working well. The only drawback to this is that I've noticed the sedan does take a hit in the handling department with 14" snows. Probably the combination of smaller rim and softer tire. I would imagine summer wheels either wider in the stock 15" or larger diameter would really improve the handling.
Old 12-08-2018, 05:55 PM   #3
dogsridewith
Drives: 2007 2-door hatchback
studs effect on handling maybe?
Old 12-08-2018, 06:14 PM   #4
DarkShadowFox
why would you use smaller tyres.
Old 12-08-2018, 06:20 PM   #5
tmontague
tmontague's Avatar
Lots of reasons:
Cheaper tires, more cushion for potholes and smoother ride so on and so forth.
I use 14's for that reason. I'm not too interested in driving for performance in the winter anyways, so the hit to performance isn't really a big deal
Old 12-09-2018, 06:08 AM   #6
Hoodyjay
Drives: 2007 Toyota Yaris Sedan BASE
Hmm my car sticker in the door says I use 175/65/14 tires. I use them winter and summer. Can I up a size?
Hoodyjay is offline   Reply With Quote
Old 12-09-2018, 08:15 AM   #7
dogsridewith
Mind of Toyota three percent OEM spedometer error?
175/70/14 tires is the easiest way to get to the same 3 percent greater tread circumference as the stock 15" setup on the higher model of your car.
Do some searching here on winter tires...I posted pictures and description of175/70/14 winter treads on my 07 hatch.
Old 12-09-2018, 05:37 PM   #8
thetoyotaman
Drives: 2009 Yaris
Correct. The 175/70/14 gives same as stock diameter. Negative sizing in this case allows a narrower tread for better traction. The smaller tire and prius alloys save weight to try to give a little fuel efficiency back. Downsides are the handling. But, the priority is traction.
Old 12-09-2018, 06:14 PM   #9
dogsridewith
It makes the owner think the base model gets better gas mileage than it does, and gets him back for an oil change sooner. Or maybe the base model is correct and the up model is off 3 percent. Or maybe Mind of Toyota calibrated the speedometer differently for the two vehicles. (I've asked this question of single or dual calibration a few times here.)
For summer wheels, I also gained the 3 percent for the base rim diameter w/ 1/2 inch wider stock Miata 14" rims by fitting 185/65-14's.
Old 12-11-2018, 11:38 PM   #10
thetoyotaman
Drives: 2009 Yaris
I haven't checked on the Yaris, but on the Echo there is 2 different speedometer gears available in the USA for different tire sizes. I would guess the same here. Very common for Toyota to do.
Old 12-12-2018, 09:18 AM   #11
dogsridewith
How did you find that Echo had two speedo gear sets? (Thinking that at some point, it might be possible/easier to do this by programming.)
Old 12-15-2018, 01:47 PM   #12
thetoyotaman
Drives: 2009 Yaris
I have a good relationship and discount at my local dealer. I just had them look up the speedometer gear options. Very common for Toyota to have the shaft gear and the speedometer gear have a range that work together. As long as they are matched you are good. If they are not the plastic gear will chew up. You can also wire in a yellow box and program it. Just depends on what your goals are.
Readiness Test Not Ready? BLH DIY / Maintenance / Service 3 05-08-2017 01:16 PM
Satellite Radio Ready antenna? ArmyManNB In Car Entertainment + Electronics (audio / video / alarm) 0 07-07-2013 09:12 PM
gettin the car ready for summer... enviri Photo-Video-Media Gallery 0 04-18-2010 01:45 PM
ready for snow my little snow ball Canada 52 12-29-2008 02:02 PM
Are you ready for the Holidays????? Bob_VT Off-topic / Other Cars / Everything else Discussions 15 12-24-2008 07:59 AM
