![]() ![]() Drives: 07 yaris Join Date: Dec 2016
Transmission line leak
Hey guys posted a while ago about having a transmission leak which i thought was from the pan gasket but upon further inspection its from one of the trans. lines going to the radiator. Is this an expensive/hard fix? It's not the rubber hoses but from the steel lines.
Pictures?
AFAIK, transmission oil is not cooled in the Yaris? I might be wrong.. Are you sure it's transmission oil? Oil might be dripping to the AC line? Sent from my VTR-L09 using Tapatalk |
You can buy a new hard line but chances are the small 10mm bolts holding it on are rusted and will shear off.
This happened in my '05 Vibe. I purchased some rubber oil lines and just used those to run to the trans cooler in place of the hard lines. I then used the figure 8 zip tie method to keep the lines from rubbing together or rubbing anything else. Has so far worked well for the past 25,000km
Oh its definitely transmission fluid! Theres 2 lines that go to the radiator from the transmission. And I've been slowly having to top it up every couple weeks or so depending on how much driving I do. It's hard to get a good look at it for a picture. I'm hoping it's an easy fix.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Transmission leak. big time!!! | misterno | General Yaris / Vitz Discussion | 6 | 05-15-2016 03:47 PM |
| Installing a external in line transmission filter. | YarisSedan | Performance Modifications | 1 | 03-31-2009 08:03 PM |
