Old 11-07-2018, 11:52 PM   #1
thetoyotaman
Drives: 2009 Yaris
2009 Yaris erratic idle
Occasionally my Yaris seems to want to low idle around 500. Ideas?
thetoyotaman is offline   Reply With Quote
Old 11-08-2018, 08:23 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Toyota Tachometer
What is measuring this rpm? Just the arm arm on the OEM dial tachometer in the instrument cluster? (I don't have tach option, so don't know if there is a digital readout.)
Is car auto or manual? In what gear positions is 500 rpm idle?
Old 11-08-2018, 08:25 AM   #3
Leegamer
Leegamer's Avatar
Do you have a CEL?
Old 11-11-2018, 05:27 PM   #4
thetoyotaman
Drives: 2009 Yaris
Analog tach goes down and I can feel the engine dropping rpm. It’s a stick. Notice it stopped in neutral.
Old 11-11-2018, 05:47 PM   #5
billfires
Drives: 2010 3dr LB
I have a 2010, 140,000 mile, manual trans, that does the same, has done it since new. Bill C
billfires is offline   Reply With Quote
Old 11-12-2018, 08:23 AM   #6
dogsridewith
Normal is only 600 rpm. Feels slow compared to 91 manual 1600 Corolla 750 spec rpm.
Can see 100 rpm on gauge that swings to? 8000?
Old 11-13-2018, 08:32 AM   #7
Leegamer
Leegamer's Avatar
I can say that the idle in my 08 manual hatch has always been....asynchronous? It tends to drop and then rise every few seconds, but never low enough to where it feels like it's going to stall. I drove another yaris a few years ago that did the same thing.
Old 11-13-2018, 08:38 PM   #8
dogsridewith
Toyota Yaris low hunting erratic idle Corolla timing
The 1991 Corolla 4A-FE has a hunting spark advance at idle...you can hear it in the stock intake. To check timing, you place an electrical shunt somewhere so the idle timing stays in one place. Mind of Toyota.
(Consistent w/ factory shop manual. I think hunting can be a way to optimize some tuning parameter(s).)
I think my Yaris idle is pretty steady. Cooling fan and/or A/C cycling, and maybe alternator voltage regulation, could cause idle fluctuation.
Old 11-14-2018, 05:59 AM   #9
CB900F2
Drives: 08 Sedan
Clean your MAF sensor and then pull you battery cable for 1 min and reisntall
CB900F2 is offline   Reply With Quote
Old 11-14-2018, 01:49 PM   #10
DarkShadowFox
low oil pressure. try that, just a guess.
Old 11-14-2018, 02:35 PM   #11
By the needle, warm engine, mine idles 500 rpm on the nose.
Sent from my EML-L09 using Tapatalk
Old 11-15-2018, 12:50 PM   #12
dogsridewith
Toyota Yaris idle speed
Using pin 8 (or 9?) on Hal's 16 pin OBD connector, and a ground to a mid level digital multimeter set on "frequency," my 2007 manual Yaris warmed up would, and may still, idle at 600 rpm...exactly 600.
FS: 2009 Yaris 3dr left-overs jecurtin3 Items for Sale by private party 12 08-09-2013 02:57 AM
Just bought: 2009 Yaris Sedan Prometheus Bound New YARIS Purchase Forum 2 05-11-2013 11:45 PM
