OBD II based etest pass with 2zr swap
Well, it's been confirmed. In Ontario I passed the etest with a swapped 2zr and an xd ecu. It should he noted that i used tech stream to rewrite the chassis VIN into the ecu. You ca n pay the dealership to do this or do it yourself with the software and cable like I did. However, you should still pass with a different EVU VIN they just might ask you if you have replaced the ecu and you can say you did so due to the original one breaking.
They never asked me any questions and it passed as usual. Ontario no longer requires etests for non commercial vehicles as of April 2019, but I needed mine for January. Figured this is useful info for anyone who lives in a jurisdiction that requires an etest that is simply an OBDII scan. Let's the swaps begin!
Congrats! That's awesome. So they don't stick a probe in your exhaust pipe? Just OBD2 scan for emission related codes? We've never had emissions testing here in NB - too rural, I guess. LOL
#3 | |
#4 | |
My van, this time. It should pass.
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Same thing here in California. Taylor passed the OBD smog check with the correct vin in The ECM
So it's possible to go 2ZR swap here in CA and stay road legal, correct?
Data doesn't lie
That’s correct sir, but you need to re-write the vin and engine info to the new ECM.
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| 3rd gen engine swap, 2ZR? 2AR? Swap newbie | m.flores.0928 | Third Gen Yaris General Discussion | 6 | 10-02-2020 10:54 AM |
| 06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 08:12 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Information for 2zr fe engine swap in my 2012 ncp131 Yaris | 20yaris12 | Third Gen Yaris General Discussion | 0 | 07-03-2016 12:00 AM |
