![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
Putting together a small tool kit to keep in my 2009 hatch...
Just wanting to keep a small tool kit in the car to cover most common nuts and bolts...
It seems like a small metric socket set would cover a lot of stuff... any suggestions for anything else? Types of screw drivers, maybe a magnetic pickup tool for when I inevitably drop a socket into the bottom of the engine bay... I've also got gloves, some compact blankets a, LED water proof flash light, jumper cables, and am about to swap in a full sized spare and a small Rotopax gas can once I detach the riser in the spare compartment. I've got AAA roadside as well - but I'm somewhat of a prepper so if I can undertake a quick fix instead I'd prefer that! With the mileage I have I want to be prepared for at least small roadside misadventures.
3 Yaris and counting..
Fuses, mechanics wire, flat head screwdriver, adjustable wrench.
In general its pretty unusual for a good running car to suffer a show stopping breakdown, even if it has 200,000 miles on it. Especially a Toyota. Its even pretty unusual to have a flat tire.
Better than carrying a tool kit is running the 30,000 miles inspection as found in the owners manual once a year on a regular basis. Once a battery is three years old checking the voltage drop while starting the engine (replace the battery if voltage drops below 10) every so often should keep a dead battery from stranding you.
Mechanics wire has saved me more than once after nailing road kill. My exhaust was separated right after the cat. Tied up the rest of the exhaust to get me to the shop to have it welded.
However, I do agree with the above post. I'm diligent with my maintenance and as a result, none of my cars in the past 12 years have seen a tow truck. The last one that did was the result of a blown rad. No prior leaks, just a one time catastrophic failure. Not much you can do about that unless you replace your rad "just cause"
#5 | |
I periodically run a battery tender at the house and check the battery about once every 2 weeks to once a month too! Fuses and mechanics wire I hadn’t thought of though! |
![]() ![]() Drives: 2008 Yaris 3DR Hatch MT Join Date: Dec 2018
Safety triangles or emergency flares.
12-volt air compressor Duct tape Mobile phone charger. First Aid kit. Folding shovel WD-40 Ice Scraper with Brush Can of Fix-a-flat Multi-tool Zip ties Olde tyme paper road atlas Glock 19 (optional) Last edited by 2bz; 02-15-2019 at 02:17 PM. |
#7 | |
![]() Yeah I would take $200 and go to Harbor freight and BUY BUY BUY!
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
MREs? I keep a jacket or 2 in my car, too. Maybe a good book in case you're stranded and have crappy cell service.
I'm a hermit named Lee |
I like to bring along an extra serp. belt - usually a used one - just in case. My little box also contains a small tool kit. I plan to pick up a small 12V compressor (small enough to fit under a seat) and a tire plug kit. If I'm going on a long road trip in the van, for example, I bring along a liter of each, motor oil, atf and coolant. Everything fits well into a small cardboard box.
I don't worry about a portable compressor. But then again, I have a self sufficient air system to power the 2 air horns stuffed between the rad and engine hahahah
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Blending a Kit With a Factory Bezel | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-02-2010 11:54 PM |
| A few small OEM Parts from 2008 Yaris LE Hatch | white_rice | Items for Sale by private party | 0 | 03-20-2010 05:29 PM |
| The small cars of the 2009 LA Auto Show | Thirty-Nine | Off-topic / Other Cars / Everything else Discussions | 2 | 12-16-2009 02:50 AM |
| another small update on turbo kit. | joey1320 | Forced Induction Forum | 6 | 08-23-2007 04:51 PM |
