Old 02-15-2019, 11:47 PM   #1
Phatdonkey78
Drives: 2007 Hatch
2007 hatch front passenger ball joint
Back in 2015 I replaced the front passenger lower control arm for my brother in law on the yaris I now own. It was a bear to get the front LCA bolt out to swap it. Is it possible to replace just the ball joint? I went to get an alignment and that ball joint is shot so they won't do the alignment. I see moog makes a ball joint (pn k500118). Just curious if anyone has successfully replaced just the ball joint.
Phatdonkey78 is offline   Reply With Quote
Old 02-16-2019, 08:45 AM   #2
ex-x-fire
I haven't on any Yaris, but have on other imports. You'll need a ball joint press & a snap ring plier. It's too bad Toyota didn't use the bolt on ball joints on the Yaris like it's other cars.
Old 02-16-2019, 10:57 AM   #3
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Anyone ever notice how similar (pretty well exact copy) the yaris front end is to a mk2 or 3 vw? They use bolt in ball joints though. Makes for a change anyone can do with basic tools.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 02-16-2019, 11:14 AM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
If it's not an original LCA, then I'd advise against just changing the ball joint. Besides, you will have to remove the control arm to knock the ball joint out anyways.
Sent from my CLT-L04 using Tapatalk
Old 02-16-2019, 12:56 PM   #5
myfirstyota
Naa, just rent a ball joint press. Like a big c clamp that has different size cups you can use to press the ball joint out while the lower control arm is still in the car.
It doesn't appear to be being used properly in this pic but you can see the idea
2007 Yaris hatch - thinking TRD Type-Y General Yaris / Vitz Discussion 18 01-18-2018 11:47 PM
Ball Joint Replacement? zoidberg444 DIY / Maintenance / Service 4 05-03-2017 09:55 AM
URGENT. BALL JOINT REINSTALLATION QUESTION xb visitor DIY / Maintenance / Service 4 05-09-2014 07:02 AM
Front Lower Ball Joint Cotter Pin Replacment GrayYaris DIY / Maintenance / Service 5 04-25-2014 05:30 PM
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 07:27 PM
