Old 04-21-2019, 01:37 PM   #1
logoris
Drives: 2017 Yaris SE Blue Streak
Brake pedal travel
I just noticed today that the brake only moves probably 3 to 4 inches, is this normal? I tried lifting the pedal and there is no movement backwards.
And if the battery is disconnected do I need to do anything related to the abs module or is it ready to go once battery has been connected
logoris is offline   Reply With Quote
Old 04-21-2019, 03:09 PM   #2
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Brake pedal travel souds about right. Youre good to go with the abs.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 04-22-2019, 06:42 AM   #3
logoris
Thanks.
Just never paid attention to it
Hiss or pfft when pressing brake pedal kwk442 DIY / Maintenance / Service 3 06-03-2017 06:10 AM
Brake pedal goes stiff under heavy braking, no ABS engagement? CrankyOldMan Tracking, Racing, Auto-X Forum 6 05-26-2015 09:09 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Brake pedal vibrates-not rotor problem rradhay DIY / Maintenance / Service 9 11-12-2010 09:10 AM
