#19 |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Got it solved.It was a thicker metal flange around the exhaust.A spot weld came undone.Mechanic retacked and all is good.
#20 |
#21 | |
Clackling sound only hot weather.
Had 2 mechanics go over exhaust while having other work done. I do notice I only get the noise in really hot weather, Not a peep all winter and cooler months. |
#22 |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
do you get a manual trans? if yes then check the 2 shifter cables if they are rubbing against each other... i just had a hard 2 months figuring out mine and lamost ordered a clutch set as advised by 2 shop mechanics i went... with endless troubleshooting i even got 1 bolt off the exhaust damaged since i suspect the exhaust was making the sound.. when moving the engine while it is off, there is a slight sound too but that is near the exhaust and just the 2 shifter cables grinding each other... i could be wrong but it is worth a try if you have the stick shift. I placed a rubber cushion in between the metal guide and put a little grease and voila all the unusual metallic sound are gone.
#23 |
Thanks and will check.....only hot weather is it present.....not a peep in colder weather.
AGAIN...ONLY HOT WEATHER noise appears!!!! |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| Raising the sound stage... | SAV912 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 07-30-2011 05:26 AM |
| Odd Metallic Sound From The Engine Bay | Kaotic Lazagna | DIY / Maintenance / Service | 5 | 08-29-2009 03:03 AM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 03:11 AM |
