#19 |
3 Yaris and counting..
Any insight as to where your new front lip came from?
Imgur sucks now too...
#20 |
I may be wrong, but it looks like a 2000ish Civic lip.
#21 |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
#22 |
Any major modifications to get installed?
Fitment looks decent in the pic... it's decent in person?
#23 | |
In a nutshell, trim the top that normally screws into the civic bumper and then get a heat gun and start bending it to the shape of your bumper. Grab a few self tapping screws to hold it on and you're done. If you plan it out right, you can screw it into the bumper from the bottom so you don't see any of them. I was short on time with this one so I just screwed the lip onto the bumper from the front and sides. Not noticeable from afar because they're black but you can see them for sure if you're looking for them. If you look at my car up close it's far from perfect but my bumper is also mangled from an accident so I didn't put too much effort into making the lip fit absolutely perfectly to my imperfect bumper. Also, I go through these things every few months with all the construction on the highway so I don't invest too much time or money into any lip I make. I look at these as throw-away items since it's on the bottom of the car and gets smacked into everything so I never spend more than $20 on a lip ![]() If you want a way easier option, garden edging works nicely and looks decent. Only issue I had with it, when I single layered it, it would flex on the highway. Put some backing on it for rigidity and it's good to go. I use the 4" tall version with the sort of rounded bump edge. Heat it up then flip it upside down so the part that goes in the ground is screwed or zip tied to the underside of the bumper. Way less cutting and easier to mold to the bumper. Don't think I have any pictures of this one if it's not in the thread; sorry. Anyways hope this helps! |
#24 |
How did you handle the ends of the lip? Since the civic lip is a lot longer than the Yaris front, I had to shorten the two ends and cap them.
#25 |
Sure does help. Thanks heeroyuy
#26 | |
No problem, glad I could help. Really like your build thread, hoping to swap to a 2zr next year as well.
#27 |
Do it! That car has to be one of the most fun cars ive ever driven.
| 2012 Audio Upgrade FAQ and Build Log | muffin_top | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 01-19-2022 06:28 PM |
| Build thread! '08 Yaris Hatch | nimuntak | Photo-Video-Media Gallery | 105 | 01-28-2014 02:28 PM |
| The open political discussion thread. Read the first post! | eTiMaGo | Off-topic / Other Cars / Everything else Discussions | 342 | 09-15-2009 12:34 AM |
| Aftermarket rim thread vs official wheel guide | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 04-01-2009 12:11 PM |
| Post Whores-aka Yaris chat thread | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 21 | 07-12-2007 05:37 PM |
