![]() Drives: 2015 Yaris Liftback LE auto Join Date: Mar 2019
Is the DIY unlink AC defrost the same process for the 3rd gen?
Hello I really do not like how the AC comes on when I turn on defrost. I simply want heat to blow. I don't want AC blowing and making the car sluggish for no reason. Is it the same process to unlink the 2 just by breaking off the metal tab as shown in this thread? http://www.yarisworld.com/forums/showthread.php?t=10888
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I haven't really noticed the AC making the Yaris sluggish while defrosting.
The AUDM version here does not automatically turn the AC on whe switching to defrost. However, I notice that turning on the AC while on defrost helps clear the siee windows and the rear view mirror. The AC is basically only being used to dehumidify the air when defrosting, helping tomclesr the windscren faster.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#3 | |
I have a copy of the service manual on my Google Drive. You should be able to grab it here: https://drive.google.com/open?id=1-f...tMOb0QO-N6rw1-
You will need to download the file, unzip it and then use a web browser to explore it. The wiring diageam shows the green wire goes from the AC push button swigch to the AC control module. I suspect there is a link from this switch to a second switch that will operate when the mode dial is turned to the Defrost position. This would be the link to cut, not the one from the On/Off switch.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. Last edited by kevinj93; 10-04-2019 at 10:58 PM. |
#5 | |
This did the trick, the AC doesn't automatically kick on anymore when I turn it to any of the defrost positions. If I ever need AC in those positions, I can manually turn it on myself!! Got it all back together. |
Glad you got it sorted out.
| DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) | CTScott | DIY / Maintenance / Service | 12 | 01-22-2022 03:09 AM |
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| 3rd Gen Sport Pedals ? | NYC-SE | Cosmetic Modifications (Exterior/Interior) | 14 | 11-10-2018 08:46 PM |
| 2nd vs 3rd gen ride quality + durability | chocolab | Third Gen Yaris General Discussion | 23 | 11-17-2014 07:30 PM |
| 2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) | nookandcrannycar | General Yaris / Vitz Discussion | 7 | 02-22-2014 08:16 PM |
