#19 |
![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
Then put pump pulley then alternator on. Final tightening pump pulley with by on. I will ass a few more pics later .
#20 |
Photos of how to pry alternator . Pry alternator til it hits adjustment mark made with a Milwaukee jobsite marker. Tighten 12 mm bolt with right hand while holding pry bar/ alternator in place with left hand. Pry off motor mount as shown
#21 |
12mm Wright ratcheting wrench on alternator tensioner
#22 |
Torque specs : 14 lb ft alternator tensioner
40lb ft alternator bottom bolt 11nm 97 inch lbs water pump bolts/nuts 13nm 115 inch lbs water pump pulley bolts 9nm. 80 Inch lbs thermostat housing |
#23 |
Couldn’t fit a torque wrench even with a crows foot or torque adapter on water pump pulley . Tightened with a 0 offset hazet 10x11 TIL pulley moved and slipped belt .
#24 |
The gasket scrapers. A razor blade at 90 or a SK gasket scraper with my thumb on top so it stays flat .
#25 |
I replaced factory hose clamp with a work drive clamp. It was hard to get back on thermostat housing even when compressed all the way with hose clamp pliers .
#26 |
I used a asin water pump and gasket. Genuine Toyota thermostat o ring. Stant thermostat . Had alternator rebuilt at chestnut hill electric for $108. It got new brushes , bearing and voltage regulator.
#27 |
10mm deep socket , 1/4 drive tekton ratchet negative battery terminal
#28 |
Due to close proximity of fender, it takes some maneuvering to get alternator and water pump in and out but definitely doable.
#29 |
This looks like quite a bit of work! Gosh I miss my old Skoda 105, I could change this in 5 minutes there!
#30 |
Wasn’t too bad. Had to finagle water pump and alternator in and out. Thin head ratchets helped a lot. It was very hard to keep socket on lowest water pump bolt when torquing to spec. Plus it was a pain scraping the minimal rubber gasket residue off due to tight quarters .
| Water pump replacement guide? | Mrb | DIY / Maintenance / Service | 5 | 02-05-2019 01:05 PM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 08:55 PM |
| Location of Water Pump | lululovesu | DIY / Maintenance / Service | 1 | 10-19-2014 08:05 AM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 12:33 PM |
| Rear Shocks Replacement? Water Pump. | babytic | DIY / Maintenance / Service | 7 | 06-15-2013 03:55 PM |
