Old 02-22-2015, 12:40 PM   #19
Rakin
Drives: Toyota Premio NZT240
Originally Posted by JudgeM View Post
Tried it, does not work. What type of adapter are you using ?
I managed to get this other shitty app hOBDrive demo to get some readings, but for some reason I cannot get Torque to get readings.
It's connecting with your code, but no readings. I tried some more codes I got from the net, same result.
ELM327 $6 adapter from ebay. It only works on 2002-2006 cars, tried it on a 2008 NZT260, didn't work. :(
Rakin is offline   Reply With Quote
Old 03-03-2015, 06:19 AM   #20
KTS
KTS's Avatar
Drives: Vitz RS
The app OBDDash free on my windows 8.1 tablet was able to connect well enough with my 2007 Vitz RS using ELM327 to read DTCs.
KTS is offline   Reply With Quote
Old 03-22-2015, 06:56 AM   #21
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Hi KTS,
Did you have to use any custom initiation strings ?
Oh man I don't want to buy a Windows tablet. If these things work on so many other devices/platform I am sure there is a way to get it to work with Torque.
JudgeM is offline   Reply With Quote
Old 03-22-2015, 07:31 AM   #22
KTS
KTS's Avatar
Drives: Vitz RS
I am not sure what you mean by custom initiation strings.
I just installed the app and clicked on connect and I was able to read the dtc associated with the check engine light but provide no real time data.
I then started unplugging connectors in the engine bay and checking the codes to verify if it was reading the correct codes and it was.
Also the mini vci cable and techstream v10.something works on my windows 8.1 tablet.
Old 03-23-2015, 03:54 AM   #23
JudgeM
JudgeM's Avatar
Ah I see.
Yea some apps can read the DTC but no real time data.
hOBDrive shows real time data but its $25 and has a shitty ui.
It must be something small. I've managed to get Torque to connect successfully to the ECU just no readings.
I am going to try some more apps I found recently online
Old 03-23-2015, 07:01 AM   #24
KTS
KTS's Avatar
Drives: Vitz RS
I am hoping you will compile a list of apps and their settings that connect and show either dtc and rtd or both
Old 03-23-2015, 09:36 AM   #25
FredsToolbox
Drives: nc
Sorry , don't want to sound like a stalker here. I am the developer of the OBDdash app. I found this post via google.
I found it surprise that the live data does not work for you given that the check error code works fine. Can you please provide a bit more details about this issue?
On the gauge screen, if you tap on any empty gauge, does the app shows a flyout? if so, does the flyout contains any sensors? If there are sensors listed on the flyout, single tap on any of them should assign this sensor to the gauge, and live data should be displayed thereafter.
FredsToolbox is offline   Reply With Quote
Old 03-23-2015, 08:58 PM   #26
KTS
KTS's Avatar
Drives: Vitz RS
Hi FredsToolbox,
I do not have the elm327 atm. I lent it to a friend to check his car. As soon as I get it back from him ill try what you suggest and let you know.
Great job on the app!!!
Old 03-24-2015, 03:05 AM   #27
JudgeM
JudgeM's Avatar
Hey nice to meet you FredsToolbox.
Any chance of an Android version of your app ?
Old 03-24-2015, 03:09 AM   #28
FredsToolbox
Drives: nc
Sorry, wasn't any plan on the Android move :(
On the bright side, when I did a search of OBD on google play store, I think it returns over 100 apps :)
The reason I made this on Windows tablet is just to fill the void as there was Zero OBD app for Windows tablet at the time I started :)
Old 10-03-2019, 02:32 PM   #29
mik23
Drives: yaris 2005
Has anyone got elm327 commands for yaris
Sent from my SM-G930F using Tapatalk
mik23 is offline   Reply With Quote
Old 10-13-2019, 02:40 PM   #30
sceh
Drives: yaris 2004
FWIW, I bought a cheapish ODB scanner from Ebay which was meant to be for the Yaris. It ruined the entire car. Nothing worked afterwards. The engine idled at 300 revs, the gearbox didn't work etc etc.
So, I bought another specific to Toyota (can't remember the name but it was a Canadian company). Rubbish. The bluetooth connection never worked and it told you wonderful things like your road speed only when it did work
sceh is offline   Reply With Quote
Tomtop ELM327 Bluetooth OBDII Reader Betrivent General Yaris / Vitz Discussion 31 06-12-2011 06:22 PM
ELM327 BT OBDII Dongle sleey0 Items for Sale by private party 9 10-15-2010 10:09 PM
Bluetooth CAN OBD2 Wireless reader for labtop or other bluetooth device $75 YarisSedan Items for Sale by private party 1 01-22-2009 07:18 PM
Bluetooth OBDII WolfWings In Car Entertainment + Electronics (audio / video / alarm) 5 09-01-2007 05:44 PM
