Old 10-19-2019, 10:36 AM   #145
Another thread I just discovered, which is making me think about lifting my own car too Following!
Old 10-19-2019, 07:20 PM   #146
Remember the old days when responses were something like;
"Nice ride. Now...
- drop it!
- slam it!
- take care of that wheel gap!
- get rid of the 4x4 look!"
Changing times indeed. Just like the old quest for 18+ inch wheels.
Old 10-19-2019, 08:08 PM   #147
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Pretty sure I seen a lifted scion frs tonight. It definitely had larger tires on it. Also, my buddy showed me a video on YouTube of a mk4 jetta that the owner lifted and added 215/75/15 tires. Same size I'm going for.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 10-20-2019, 01:19 PM   #148
"Nice ride. Now...
- drop it!
- slam it!
I actually blame that one fast and Furious movie where they ruggedized the Charger, WRX, etc...
Old 10-23-2019, 10:18 AM   #149
myfirstyota
Old 10-24-2019, 08:42 PM   #150
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I know it's still hanging, but can't wait to see side shots when she hits the ground. So cool!
Old 10-24-2019, 10:33 PM   #151
myfirstyota
Only reason it's on jacks was so I could take the tires off to make room to work.
It's basically driveable but needs the exhaust realigned to jive with the new engine height and an alignment. Haven't extended the sway bar links yet either. Also need to get the new, bigger tires and make sure they fit. I may still have to make room in the rear. But technically you could bomb around a field with it as is, although I bet it would be loud!
Priced out some bfg ko2's today. May order them tomorrow. But KAL tire says probably 2-3 weeks to get here. Coming from B.C. they said.
Im taking this time to rewire some of my accessories. As things were added, it got messy. I'm hoping to have the car ready for the exhaust shop and alignment by halloween
Old 10-27-2019, 10:22 AM   #152
myfirstyota
Old 10-28-2019, 08:33 AM   #153
myfirstyota
Does it ever really end?
Old 11-02-2019, 10:50 PM   #154
myfirstyota
Maiden voyage
Old 11-03-2019, 01:45 PM   #155
myfirstyota
The 27.7" tall BFG K02's still aren't in
Old 11-04-2019, 09:18 AM   #156
Leegamer
Leegamer's Avatar
fantastic
I'm a hermit named Lee
Old 11-04-2019, 05:01 PM   #157
06YarisRS
YES! It looks AWESOME!!!
Old 11-04-2019, 06:41 PM   #158
myfirstyota
Dropped the rims off this evening to kal tire. Should be ready by tomorrow
Old 11-04-2019, 08:41 PM   #159
06YarisRS
What are the dimensions on the K02's? I get that they are 27.7" tall, but are the tires spec'd in the typical xxx/xxRxx size? I'm pumped to see this beast with the A/T tires on it.
EDIT: Ignore my question. I just read a bit farther up in the thread. 215/75R15. Maaaaan, that is going to look insane.
Here is a comparison between what I currently have on my turbo Yaris and what you'll have:
Isn't the rim only 5" wide? Or maybe you got wider rims. I will have to go back and read your entire thread.
Old 11-04-2019, 10:40 PM   #160
myfirstyota
The rims that they are going on are VW corrado g60 steelies. I believe they're a 15x6 or 6.5. I'll have to verify when I pick them up tomorrow
Old 11-05-2019, 05:55 PM   #161
myfirstyota
Old 11-06-2019, 11:07 AM   #162
oh yeaaaaaaaah
Finally bought a lift CTScott DIY / Maintenance / Service 26 09-28-2010 09:09 AM
zage turbo kit..! just need some help joseyaris Forced Induction Forum 12 10-29-2009 08:35 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 08:42 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
