Old 10-22-2019, 02:04 PM   #1
sv650steve
Drives: accord (for now)
Fuel line issues
My fuel line got hard and got a hole in it by the fuel pump. Where does this lead to? Do I have to drop the tank? What kinda hose do i need?
sv650steve is offline   Reply With Quote
Old 10-22-2019, 04:50 PM   #2
Brighton
Knower of little
Drives: None
There should be an outlet and return line as well as a vent line. They more than likely are tucked up above the tank so you will probably have to drop the tank to get full access to them. The outlet and return go up to the engine bay and only the portion of line by the tank and in the engine bay are rubber, the rest are metal. To replace them, figure out if they are 1/4 or 5/16 size (maybe even 3/8) and then get line rated for fuel and or ethanol. Pretty easy to replace once you get access to them and fuel line can be found at any auto parts store.
Brighton is offline   Reply With Quote
Old 10-29-2019, 05:32 PM   #3
sv650steve
I ended up getting the whole part. It popped in pretty easy, but i rigged it up for a while which may have pinched my fuel line and killed my fuel pump? IDK check my other post.
Magnets for the fuel line? bairjo Fuel Economy Forum 4 04-02-2013 07:27 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
