![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
No heat unless...
If I start the car I dont get heat untill throttle is touched.
The car can sit firever idling but heat will not come out untill I tap the throttle. Never encountered this on any car before.Once the heat comes it is at normal hot temp.Could be thermostat issue? UPDATE: May be a faulty waterpump.I will try and findout how to diagnose and see if this issue. Last edited by Pinchlite; 11-05-2019 at 10:06 AM. |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Also check coolant levels.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
The white plastic container in back of the radiator seems to be at proper level.
I have read that air trapped could cause improper heat. |
That's exactly what I was thinking. Let the engine cool and pop the "rad cap". See if there's coolant in the hose.
I dont not see coolant with cap off.I thought that was normal seeing reservoir was at normal level.
I think the air in the system doesn't allow proper flow of the coolant resulting in inadequate flow to the heater core. When you hit the gas, I'm guessing the water pump spins faster and forces some coolant to the heater core.
But that's my guess...
I read you can take cap off and start engine to eliminate air?
Cold engine of course. |
Yep. Top off coolant, Run engine till fan kicks on, top off again and cap on. That's how I bleed the air in my engines... unless there's a bleeder valve which I dont think the yaris has.
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Try squeezing hoses to help circulate and remove air. Fill radiator
to bottom of neck. Any excess will go to tank. Cap radiator after steady level is maintained. |
That's when you know for sure the thermostat has opened. That allows the coolant to flow through the engine pushing the air bubbles to the top of the system, which in the yaris's case is the 'rad cap'. Thus purging the cooling system of any air.
Okay.Makes sense know. |
| Heat shield fell off... | komichal | General Yaris / Vitz Discussion | 4 | 06-11-2017 03:46 PM |
| engine overheats, no cabin heat, fresh serpentine - 07 yar 3dr | frostbitten | DIY / Maintenance / Service | 5 | 03-19-2014 09:58 AM |
| LEDs and heat | SaerinRhoe | Cosmetic Modifications (Exterior/Interior) | 10 | 01-02-2010 09:34 AM |
| heat barrier | auto pal | DIY / Maintenance / Service | 1 | 06-27-2009 05:29 PM |
