![]() Drives: Yarus Join Date: Nov 2011
Injector Replacement
I'm looking for advice on injector replacement, not cleaning and reusing.
I found remanufactured ones for as cheap a $40 each. New as high as $188 each. I really don't have the time to dick around so it's a replacement and back to work deal. So I seek the answers from the knowledgeable on the following questions: 1. new or remanufactured? 2. brand? 3. is there an o ring kit available? 4. what other parts will I need to do the job Trying BG 44 first. Thanks, Mark |
Why do you feel you need to replace your injectors?
did the screwdriver stethoscope method and one intermittently is fairly noisy. If I'm there doing one, I would rather replace all 4
And that noisy injector is causing what code and or symptoms?
Sent from my iPod Touch |
#5 | |
Thanks!
I wan't aware that the injectors should be replaced unless it's throwing a CEL or is damaged. The FI's are notorious for being loud on the Yaris. I can't comment if the re-manufactured ones are just as good as brand new, but for the price I wouldn't replace all of them unless they are all bad. They aren't something that tends to go bad on the Yaris from what I've heard.
If you really want to replace the set, I have a set on hand that had low miles, plus I bench cleaned and tested them. I could sell them to you for a whole lot less than even the remanfactured set.
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
#9 | |
2ZR swap. DO IT! Ask how!
| Deatschwerks Fuel Injector Service Review | fnkngrv | Forced Induction Forum | 7 | 03-14-2014 01:15 PM |
| Fuel Injector Bench Cleaning and Testing | CTScott | DIY / Maintenance / Service | 2 | 05-31-2013 11:20 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Gumout fuel injector cleaner | Sabretooth | DIY / Maintenance / Service | 10 | 04-10-2009 11:33 PM |
| Tacoma 7th injector.. Multiple questions...... | nbays1 | Off-topic / Other Cars / Everything else Discussions | 0 | 03-23-2009 02:47 AM |
