#109 | |
JDM Fan!
Drives: '06 Yaris Join Date: Sep 2018
![]() My HID's started flickering intermittently ![]() After some investigation I found that the harness I used had started melting connectors I had to disconnect everything and I'l have to do this install all over again in the summer! I think this time I'll look for one of the Morimoto harnesses that have been great in the past. Looking forward to bright headlights again....
Regards, DeeBee |
#110 |
I too went from diode between the hi and low to Morimoto MotoControl. Best thing ever. But i do hate these housings for retrofitting (Morimoto Mini D2s 5.0) ... my driver side high beam solenoid must have been disconnected. But I have 2 six inch light bars in the grille for high beams that do so much more.
#111 | |
JDM Fan!
What's the issue with the housings? I'd think it would be easy since they are big. My Rav4 had really small headlights and it was a pain trying to get the projectors in right.
Regards, DeeBee |
#112 |
You still have to cut around the OEM bulb opening to fit the thread of the projector. Also threaded on without modification means the beam is too low. You run out of vertical adjustment. Could well possibly be I'm using aftermarkets housings as I dont have 08 style OEM, my car is 09. But the aftermarket allows me to have horizontal adjustment.
Mini D2S 5.0 is much better than the 4.0 IMO. the step isnt as big. I hated the dead zone of light on the lower step. Highbeams always looked good for these projector price range.
#113 |
JDM Fan!
Thanks for the info. I'll certainly take a good look at vertical adjustment when I make that move.
Regards, DeeBee |
#114 |
![]() Drives: 2010 NCP90R Join Date: Oct 2017
Evening all,
So after having the HID's in I'm starting to get sick of the pee coloured H7 high beams, so have been considering changing the high beams over to LED''s. Anyone else done this with the current draw from the HID headlights? Currently running a 15amp fuse. If so, I'd be interested in what peoples impressions with moving over from halogen high beams to led. |
#115 |
![]() ![]() Drives: Yaris 07 HB Join Date: Apr 2011
I change mines to LED and the different is BIG!! Try it!!
#116 |
147K-Blue / 24K-Yellow
Drives: 2010 Ylw 3dr. AT(Blue-Wife's) Join Date: Mar 2011
OK I was wrong last year about the Negative Switched, and before I go back out and start hacking on my cars (ok being too lazy, and at work, to go back out with my meter) I wonder if any of you experts know... IS The Positive Terminal on the H4 Halogen lights (Right at the bulb) "Hot" ALL the time?
OR Hot ONLY when The Headlights are turned ON? Your Input is Appreciated!
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires. Repair List: 1 new blower motor, making funny noise. @ 91K (Water pump @ 120K) Mod List: 1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott) |
#117 |
![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Aug 2017
Hi guys, so after 3 years my low beams suddenly stopped working the other day. High beams and everything else works. I’ve checked the engine bay 10 amp fuse and they are fine. Any idea where I should look next? Thanks
#118 |
ballast and bulb. its 90% most likely the bulb. both went out at the same time eh?
#119 |
Yes, at first I doubted both bulbs would go at the same time so I just ordered 2 D2R Osram bulbs from Amazon. I also tried switching out the headlight switch with a new one from Toyota and that didn't work. We'll see if the bulb solves it. Thanks
#120 |
wait you're using d2r with toyota ballasts? that might not be good...should be using d4rs... D2Rs use a good deal amount more energy to light up. It just might be your ballasts too!
#121 |
I ended up taking the vehicle to a local mechanic shop and they determined it was a bad relay. They changed it and put a new one in and it's working fine now. Where is the location of the low beam relay?
I used d2r because that is what the HID housing said to use. I also have a relay harness setup...https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
#122 |
Quick question...Has anybody tried substituting the H4 male plug with a 9006 male plug to the 4 prong connector?...I'm finding that the cheap H4 relay harness is about to die on me and keeps flickering when I hit a bump on the road after about 3 years of use and I can't seem to find a quality H4 relay harness in the market. Morimoto makes a 9006 relay harness but will require a 9006 plug, so that is why I am asking this question. Thanks
| FS: 2012 Yaris oem headlight projector retrofit | ucsmfu | Items for Sale by private party | 4 | 11-01-2016 10:28 PM |
| How can i get the OEM Headlight Stalk with FOG switch to work | murtaza.shahid | DIY / Maintenance / Service | 0 | 11-22-2014 06:30 AM |
| DIY - A EASY&FAST way to change headlight bulb | ALLBLACK | DIY / Maintenance / Service | 0 | 09-18-2010 01:40 AM |
| FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal | 03Z33 | Items for Sale by private party | 30 | 01-02-2009 06:55 PM |
| DIY - JDM RS style REPLICA tails | kurokoma-kun | DIY / Maintenance / Service | 0 | 10-21-2008 02:56 PM |
